subsonic on sheevaplug
Postby aaddame » Wed Jul 27, 2011 9:50 pm
I installed subsonic 4.4 on a sheevaplug running debian squeeze with java ejre-1_6_0_25-fcs-b06-linux-arm-sflt-eabi-headless-14_apr_2011.tar.gz
After starting it does not listen to port 4040 (I did not change the port so it is still default)
cat /var/subsonic/subsonic_sh.log shows:
167 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@f0eed6: display name [org.springframework.context.support.ClassPathXmlApplicationContext@f0eed6]; startup date [Wed Jul 27 20:06:35 CEST 2011]; root of context hierarchy
604 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
3520 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@f0eed6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1d0fafc
3623 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1d0fafc: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
3869 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/2169
4205 [main] INFO org.mortbay.log - jetty-6.1.x
Any ideas???????????????????/
aaddame
Postby aaddame » Fri Jul 29, 2011 10:28 am
I started java with the parameter -verbose:class
These are the last entries in /var/subsonic/subsonic_sh.log:
[Loaded java.net.InetAddress from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.security.action.GetBooleanAction from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.security.action.LoadLibraryAction from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddress$Cache from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddress$Cache$Type from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddressImplFactory from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddressImpl from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.Inet6AddressImpl from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.net.spi.nameservice.NameService from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddress$1 from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.Inet4Address from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.Inet6Address from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.Inet4AddressImpl from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.net.InetAddressCachePolicy from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.net.InetAddressCachePolicy$1 from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.security.action.GetIntegerAction from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded sun.net.InetAddressCachePolicy$2 from /root/ejre1.6.0_25/lib/rt.jar]
[Loaded java.net.InetAddress$CacheEntry from /root/ejre1.6.0_25/lib/rt.jar]
aaddame
