clear rating arrow no longer working in current beta
Postby system7 » Mon Aug 01, 2011 3:58 pm
Just an FYI the 'clear rating' arrow is no longer working after installing the latest beta. Tested in Chrome, IE & Firefox (latest full release versions of all 3)
system7
Postby supra92 » Mon Aug 01, 2011 6:42 pm
Interesting. Tested it here on the previous 4.5b1 and it works, so will keep an eye out for that once I get upgraded to 4.5b2 and see if I run into the same issue you do. Running ScientificLinux5.5 here, with the Tomcat6/WAR version of SS...
supra92
Postby GJ51 » Mon Aug 01, 2011 6:59 pm
Not working on my Windows b2 install. The rating cannot be cleared, but it can be modified.
Postby BKKKPewsey » Mon Aug 01, 2011 8:52 pm
Yep I concur modification ok but not clearing (WHS R1) :(
Postby supra92 » Mon Aug 01, 2011 10:00 pm
4.5b2 installed, and confirmed with the rest of you -- rating can be changed, but can't be cleared with the "reset" arrow icon. A minor bugfix for either beta3 or 4.5! :)
Supra92
supra92
Postby supra92 » Tue Aug 02, 2011 12:18 am
The other thing I noticed is that 4.5b2 hosed-up the "Created" dates, unfortunately. Hit up "Recently Added", and indeed some of the ones I added today and yesterday are there... but it's also showing some stuff I've had for years as added on 7/29/2011, etc.
But it's not like everything got reset to the same date, either -- one album I added back in 2009, is showing as created on 7/26/2011, then a couple of ones that I actually did add on 7/25/2011, then another OLD one I've had forever shows as 7/23/2011, and so forth. Really strange. Hoping it is just 4.5b2 misreading things, as opposed to it actually losing those dates for real.
supra92
Postby sindre_mehus » Tue Aug 02, 2011 5:52 pm
Bravo, great catch!
I've fixed the clear rating bug for 4.5 final.
Thanks a lot!
Users browsing this forum: Google [Bot] and 26 guests
