[ANDROID] Transcoding issue:WAV->mp3
Postby djdubd » Mon Aug 01, 2011 10:27 pm
I have the latest versions of the android app (I'm running Froyo on a Droid X) and the server app running. I have the transcoders installed in the subsonic directory.
I am using the default settings for transcoding from WAV to mp3.
The Error I receive is:
Error playing "filename".
Prepare failed.: status=0x1 (IOException)
I have tried other WAV files, even downloaded ones and have the same result.
Anyone know what is going on?
djdubd
Postby tgrhp » Tue Aug 02, 2011 10:15 pm
what does the log file say? (the log file is in the subsonic folder, if you are using linux it is usually at /var/subsonic/subsonic.log ).
tgrhp
