Android: Starting Netflix Causes Subsonic to Play?
Postby thread » Tue Aug 02, 2011 6:45 pm
I just noticed that when I start Netflix on my Droid3, Subsonic starts playing. I can't quite work around it, either, because as soon as I leave Netflix and stop the music, I'm back in the same position I started.
I turned off the "Media buttons" option thinking it could be related somehow, but it hasn't helped.
Any thoughts as to what might be happening?
thread
Postby thread » Fri Aug 05, 2011 1:41 pm
... What signals cause Subsonic to start playing, and which might Netflix be emitting when it starts? (It happens just as the splash screen is shown.)
I can't even imagine what might be causing this behavior. It's a darned mystery.
thread
Postby lyric911 » Fri Aug 05, 2011 2:33 pm
Install an app called "Headset Blocker" from the market, add and activate the widget. Not sure if that's the issue, but give it a try?
lyric911
Postby thread » Fri Aug 05, 2011 2:52 pm
Nice! Thank you for the tip lyric911!
It seems that even if I turn the widget off and remove the widget from my home screens, the problem does not recur. Uninstalling Headset Blocker causes the problem to come back.
After reinstalling Headset Blocker, I even rebooted the phone in the name of science... the problem does not recur! I don't see the app running in System Monitor right now, but it does seem to be working its magic!
I guess this is some type of solution... I wonder why Netflix feels it necessary to... emit a headset button signal? Why on earth would an app do that, I wonder.
Anyway, thanks again for the tip!
thread
Postby thread » Fri Aug 05, 2011 3:02 pm
And anyway... why doesn't turning off "Media Buttons" in the Subsonic settings prevent this from happening?(!)
thread
Postby lyric911 » Fri Aug 05, 2011 4:01 pm
thread wrote:Nice! Thank you for the tip lyric911!
Awesome. Had a hunch this was it. I had similar problems with connecting to the bluetooth receiver for my car stereo. As soon as I connected, basically all media players would start playing whatever they played last. The same widget fixed my issue.
lyric911
