Podcasts with special characters in name
Postby vollbr0t » Wed Aug 03, 2011 5:04 pm
i have some problems using Podcasts: as far as my understanding is, subsonic creates a subfolder for every podcast in the podcast-mainfolder. The folder-name of this subfolder is depending on the name of the podcast. I have some casts that contain special charaters (for example: |). Subsonic is not able to create a folder with this character (not allowed). Thus podcasts with special characters do not work :( Is there a way to get them running?
Best regards,
Jan
vollbr0t
Re: Podcasts with special characters in name
Postby vollbr0t » Sat Nov 26, 2011 1:49 pm
anyone? :(
vollbr0t
Postby sfunk1x » Sun Sep 09, 2012 1:01 am
I have not tried the beta, but the current release has not fixed the issue.
Related issues:
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=4394&p=17091&hilit=characters+podcast#p17091 Break due to | character
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=909&p=1736&hilit=characters+podcast#p1736 Fail to create directory with special character
It seems as though the bug will have a semi-complicated fix to it. Windows will not allow /\:"<>*?| to be part of folder names. I'm not sure if the same requirement exists in linux or osx. The proper way to fix this would be to catch the character and replace it with something like an underscore or a hyphen - maybe something of the administrators choosing. I'd love to see this fixed, as it breaks several of my podcasts and I can't use subsonic for what I want it to do.
sfunk1x
Users browsing this forum: Bing [Bot] and 18 guests
