No images found. w. Cover Art
Postby system7 » Thu Aug 04, 2011 2:13 pm
Has anyone else lost cover art searches via Google in the latest build?
system7
Cover Art Search not working
Postby cntrle » Thu Aug 04, 2011 2:54 pm
I have NOT upgraded to latest build, but upon a restart this morning, I have lost the ability to search for cover art.
4.4 (build 2169) – February 6, 2011
Curious.
-cntrle
cntrle
Postby tkelito » Thu Aug 04, 2011 3:04 pm
Same issue here as of yesterday, worked fine on Tuesday. Updated to the new Beta 2 release and issue still persists.
tkelito
Postby philip550c » Thu Aug 04, 2011 3:22 pm
I am running 4.5.1beta and in the last few days my album art no longer functions as well
philip550c
Postby tkelito » Thu Aug 04, 2011 3:35 pm
Are the queries being pumped directly to Google or through an intermediary? I am assuming an intermediary since the code doesn't just "change" on it's own. And it didn't work for the June or July release as I ran both. No errors report in the log.
tkelito
Postby mahikeulbody » Thu Aug 04, 2011 5:11 pm
Same problem here :-(
mahikeulbody
Postby GJ51 » Thu Aug 04, 2011 7:02 pm
Just checked mine, all's working fine.
Postby dan_i » Thu Aug 04, 2011 8:12 pm
Yeah, whatever the issue was, it seems to have fixed itself.
dan_i
Postby mahikeulbody » Fri Aug 05, 2011 3:07 pm
dan_i wrote:Yeah, whatever the issue was, it seems to have fixed itself.
Yes.
mahikeulbody
Re: No images found. w. Cover Art
Postby utopian » Wed Aug 31, 2011 7:24 pm
yep added a new album and went into subsonic.. the search under the blank artwork seems to have gone..
Running 4.5 (build 2385) – August 11, 2011
any suggestions anybody....
utopian
Postby bushman4 » Thu Sep 01, 2011 11:32 am
Do you mean that the "Change" button under the missing artwork is missing?
If so, check your user account and make sure that "User is allowed to change cover art and tags" is checked on.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby utopian » Thu Sep 01, 2011 1:22 pm
bushman4 wrote:Do you mean that the "Change" button under the missing artwork is missing?
HTH,
Glenn
ah genius man.. and what a duschbag i am... i had deleted the db folder when i got an http error so had to recreate the settings/additionals users etc which i then forgot to give the required permissions to..
Many Thanks for that... brilliant :)
utopian
