<myname>.subsonic.org is registered, but could not con
Postby dragje » Thu Aug 04, 2011 8:11 pm
Hi Guys,
After installing everything and payed for a subscription or donation fee everything worked fine yesterday. Ik could stream using the wifi to connect to my music library....
But today everything doesn't work normally :( After login in local host account: http://localhost:4040/index.view
it said (under preferences) the following:
Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding).
If your router can't be configured automatically you can set it up manually. Follow the instructions on portforward.com. You must forward port 4040 to the computer running the Subsonic server.
Status: Successfully forwarding port 4040.
That's good but under it it say
Access your server over the Internet using an easy-to-remember address.
http://<myname>.subsonic.org
Status: [/<myname> .subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Some details about my own internet connection, I don't have a static IP address, doe this might cause the problem? What can I do to fix this?
Thanks for reading in advance!
Michiel
p.s. if you need my name ( [/<myname> ) which i've been registered please send me a message, i'm not a programmer and I don't like to give too much information out so to speak, not knowing it might be good or bad :(
dragje
Postby muiz » Fri Aug 05, 2011 3:01 am
did you set the router to upnp ?
muiz
it works now... thanks
Postby dragje » Fri Aug 05, 2011 11:23 am
dragje
