Subsonic not starting
Postby rivangom » Sat Aug 06, 2011 2:04 am
Dear all,
I've got my Subsonic [Standalone version] facing an error, see below, I can't track for a solution and perhaps one of you can help.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
Powered by jetty://
The subsonic.log file in the /var/subsonic/standalone/ folder:
Synology> dd bs=32k count=1 if='/var/subsonic/standalone/subsonic.log' skip=0
[2011-08-06 02:57:30,465] INFO DaoHelper - Checking database schema.
[2011-08-06 02:57:31,006] INFO Schema25 - Database table 'version' not found.  Creating it.
[2011-08-06 02:57:31,042] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@8aa44e94[file =/var/subsonic/standalone/db/subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/var/subsonic/standalone/db/subsonic.lck] is presumably locked by another process.
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:36)
   at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:108)
   at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:65)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
   at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
Caused by: java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@8aa44e94[file =/var/subsonic/standalone/db/subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/var/subsonic/standalone/db/subsonic.lck] is presumably locked by another process.
   at java.sql.DriverManager.getConnection(Unknown Source)
   ... 76 more
[2011-08-06 02:57:31,728] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Aug 06 03:00:00 GMT+01:00 2011
[2011-08-06 02:57:35,099] INFO NetworkService - Successfully forwarding port 4040 and port 4041.
Many thanks and regards,
Robbert van Gom Neumann
Subsonic 4.8 (build 3434) Stand-alone version on Synology NAS DS1511+
rivangom
Postby Skywatcher » Sat Aug 06, 2011 10:21 pm
HTTP ERROR: 404
NOT_FOUND
Powered by jetty://
Same problem with 4.5b2 on windows.
My log complains about not being able to connect with RMI.
Reverted to 4.4 and all works again. I guess I'll wait for the final release of 4.5
Skywatcher
