<myname>.subsonic.org is registered, but could not con
Postby dragje » Sun Aug 07, 2011 12:19 pm
Dear Subsonic programmers.
I get this message:
Status: <myname>.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
The problem I have is that I don't have a static IP address, but when changing the new IP number that I get when restarting the router will do the trick. That is, it worked last time. But now I get again this message:
Status:<my name>.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Portforwing always succeed and UPNP is on.
Also port forwarding is corrected in my router:
YES TCP
start port 4040
end port 4040
<ip number>
My question is, can I solve this problem by, for example, fill in an other domain name like [b]Status: blabla.subsonic.org without it being registered? Or should I e-mail each time that my ip has changed so you guys can register it to my account?
dragje
Postby GJ51 » Mon Aug 08, 2011 1:05 am
Go to http://www.canyouseeme.org/ enter your SS port number and click the Check box to be sure the Subsonic port is open.
Users browsing this forum: Google [Bot] and 24 guests
