Cannot connect to server on computer or Android
Postby coreyb83 » Tue Aug 09, 2011 4:37 am
This is what I get from the Subsonic network settings page. My Android says network error on the same server.
Use the settings below to control how to access your Subsonic server over the Internet.
If you have problems, please consult the Getting started guide.
Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding).
If your router can't be configured automatically you can set it up manually. Follow the instructions on portforward.com. You must forward port 4040 to the computer running the Subsonic server.
Status: Successfully forwarding port 4040.
Access your server over the Internet using an easy-to-remember address.
http://.subsonic.org
Status: XXXXXX.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
coreyb83
Postby GJ51 » Tue Aug 09, 2011 5:20 am
Users browsing this forum: Google [Bot] and 60 guests
