"Most Played" list
"Most Played" list
Postby AndyIrwin2008 » Wed Aug 10, 2011 1:42 am
I have two speeds of drives that I keep my music collection on. I would like to keep the "Most Played" albums on the faster drives. All I need is text file with the list of directories that are shown by the "Most Played" screen. How can I get that information from the subsonic database?
AndyIrwin2008
Postby supra92 » Wed Aug 10, 2011 5:48 am
Hey Andy -- two steps are all it takes :)
1. Pull up your Subsonic in a browser, and change the "index.view" part to "db.view", such as: http://www.yourdomain.com/subsonic/db.view
2. In the white box, type the following SQL code:
select * from music_file_info order by play_count desc
and click the OK button.
You will see every album in your database, sorted by the PLAY_COUNT column with the most-played ones at the top.
Hope this helps, and cheers,
Supra92
supra92
Exporting query
Postby AndyIrwin2008 » Wed Aug 10, 2011 3:08 pm
Awesome! Thanks...any idea how to script that query and output to a text file in ubuntu server? I would like to copy the most played albums between drives automagically without having to output manually from a browser.
AndyIrwin2008
Postby supra92 » Wed Aug 10, 2011 3:56 pm
It's definitely doable, but you'll need to install and configure HSQLDB, which is the relational database that Subsonic uses on the backend.
Installing HSQLDB is probably a bit beyond the scope of this forum, but here are some links to get you going.
Main HSQLDB website: http://hsqldb.org/
Latest download: http://sourceforge.net/projects/hsqldb/ ... p/download
You'll want to get that installed, and a connection pointed at the Subsonic database, which is located here: /var/subsonic/db/subsonic.data
Then create a textfile containing your SQL code in, say, /home/andyirwin/mostplayed.sql
You can extract the data to a textfile like so, automating this as you see fit with a cron job:
java -jar $HSQLDB_HOME/lib/hsqldb.jar urlid /home/andyirwin/mostplayed.sql > /home/andyirwin/mostplayedresults.txt 2>&1
Let us know how this goes if you wind up pursuing it.
Regards,
Supra92
supra92
