Android client exiting after ~45 minutes
Does this happen on your Android device?
Every time, regularly on my Android device
3
25%
Sometimes on my Android device
1
8%
Never seen this on my Android device
7
58%
I don't use Android, but I felt the need to disparage it because I'm a loser.
1
8%
Total votes : 12
Postby id628 » Fri Aug 12, 2011 11:18 am
Am I the only person seeing this issue?
After about 45 minutes of playing an album (fully downloaded, not streaming), the Android client stops/exits in mid-song.
This happened with my Nexus One, with my stock Transformer Tablet, and now with my G2x running CM7.1-RC1.
Is anyone else seeing this issue? It's pretty annoying. When I restart Subsonic, it remembers which song was playing, but not the position, so it starts at the beginning.
id628
Postby alphawave7 » Fri Aug 12, 2011 2:04 pm
This appears to be an Android issue. After'sleeping' the screen, there seems to be a time limit for the app to be auto-killed by the OS, barring any additional inputs/screenwakes. Some folks use Tasker from Market to create a 'pause' for three seconds to create this interruption, until Google can fix this bug.
Postby id628 » Fri Aug 12, 2011 2:33 pm
alphawave7 wrote:This appears to be an Android issue. After'sleeping' the screen, there seems to be a time limit for the app to be auto-killed by the OS, barring any additional inputs/screenwakes. Some folks use Tasker from Market to create a 'pause' for three seconds to create this interruption, until Google can fix this bug.
Since no other music player exhibits this problem, I don't think it's a bug in Android, but rather an omission in Subsonic.
Can the author of the Android app confirm that Service.startForeground() is being called to inform the system that it would annoy the user if Android stopped this process?
http://groups.google.com/group/android-developers/browse_thread/thread/422bf837cfdb61a1?pli=1
http://android-developers.blogspot.com/2010/02/service-api-changes-starting-with.html
id628
Postby alphawave7 » Sat Aug 13, 2011 3:39 am
I beg to differ..in my experience, ALL apps I use related to music, die at 30 minute intervals, and need to be restarted. Pandora, LastFM, Slacker, etc. have all done this, on my G1, Nexus One, and now my Sensation. There are similar reports on many fora across the Android platform that discuss this.
Postby id628 » Mon Aug 15, 2011 12:39 am
Honestly, I don't use any streaming apps. I use mainly the built-in Music app and a couple in the past where I have not had it exit on any commute home at all. Subsonic does it regularly, however.
But that doesn't answer the question, which was:
id628
Postby bile » Mon Aug 15, 2011 11:17 am
It happens regularly for me. Always when loosing or picking up a signal. WiFi -> 3G, loosing 3G, etc. I've submitted logcats but never heard back about it. The logs didn't really provide much detail. It appeared that suddenly the audio device errors.
bile
Re:
Postby alphawave7 » Mon Aug 15, 2011 6:26 pm
bile wrote:It happens regularly for me. Always when loosing or picking up a signal. WiFi -> 3G, loosing 3G, etc. I've submitted logcats but never heard back about it. The logs didn't really provide much detail. It appeared that suddenly the audio device errors.
That would be more related to data pauses/drop-outs. What OP and I describe is a simple time-out with the app being killed off by the OS. Logs would not show much/any details when the OS 'cleans' by auto-kill.
Re: Android client exiting after ~45 minutes
Postby bile » Mon Aug 15, 2011 6:37 pm
There is no reason that the subsonic service should exit or be killed. The app is playing music which is pinned. I walk from the subway, the phone starts to establish a connection and the music stops and the app exits.
bile
Postby alphawave7 » Mon Aug 15, 2011 6:51 pm
bile wrote:There is no reason that the subsonic service should exit or be killed. The app is playing music which is pinned.
Precisely. Just sitting on my desk, the app will begin playing, screen goes to sleep, and 30 minutes later, POOF! (so long as other events haven't disrupted the auto-kill timer). I think this is what OP (and I) experience.
That's the data interruption I mentioned above..unrelated to OS auto-kill. :) Both issues need resolution, but I suspect by different means.
Postby mbern1008 » Fri Aug 19, 2011 4:00 pm
I think my issue may be more related to gingerbread and the way the new version of android handles background tasks. I used to be able to run subsonic in the background with no issue. Now if I run google maps and go to check mail or a text, Subsonic will stop in the background... So for multitasking it has been hurt. I have the original droid X.
mbern1008
Re:
Postby sindre_mehus » Fri Aug 19, 2011 6:29 pm
id628 wrote:Can the author of the Android app confirm that Service.startForeground() is being called to inform the system that it would annoy the user if Android stopped this process?
No, I am not using Service.startForeground(), but I will definitely look into it. Thank you for bringing it to my attention!
Postby sindre_mehus » Sun Aug 28, 2011 7:16 pm
I'm gonna look into this tomorrow. Can you please confirm that the Subsonic app sometimes exits in the middle of a song? I don't wanna keep the service in the foreground more than necessary, and it seems logical to do it only when it's actually playing something.
Thanks in advance!
Postby bile » Sun Aug 28, 2011 7:23 pm
It absolutely does exit at any point. Anything that should never be interrupted should be a foreground service. Music, downloads, etc.
A fix will be greatly appreciated. It is very frustrating having your music stop apparently randomly and the app exit. The other thing that is frustrating is lack of integration with different button events. Should I enable music controls on the lock screen set a button to start playing music it will spawn the native music app rather than Subsonic. Also the controls on my Bluetooth speaker are useless due to the same responses.
bile
Postby id628 » Mon Aug 29, 2011 4:06 pm
sindre_mehus wrote:I'm gonna look into this tomorrow. Can you please confirm that the Subsonic app sometimes exits in the middle of a song? I don't wanna keep the service in the foreground more than necessary, and it seems logical to do it only when it's actually playing something.
Thanks in advance!
Yes, it stops mid-song. Suddenly, without notice or warning.
id628
Postby sindre_mehus » Tue Aug 30, 2011 9:32 pm
Ok, as suggested I've changed the app so that it brings the service into foreground while playing music.
Could you please install the attached APK and let me know if it works?
subsonic-release.apk
Users browsing this forum: No registered users and 41 guests
