Transcoding
Transcoding
Postby RaNa » Sun Aug 14, 2011 6:05 am
ok guys all of my movies are in mkv format and is there anyway not to transcode them and play it in a external player im sorry if this is a dumb ? but had to ask when i transcode it load every 10 seconds or so and also i would love to keep my files in mkv format thank you
RaNa
Postby GJ51 » Sun Aug 14, 2011 4:30 pm
Uncheck any transcoding defined for mkv. SS will then send it to the external player directly without transcoding.
Postby RaNa » Sun Aug 14, 2011 7:58 pm
im not sure how do that but i did unclick enable but im not sure what you mean by mkv. SS thank for your help
RaNa
Postby GJ51 » Sun Aug 14, 2011 8:18 pm
Go to Settings/Players
Select the player that ypu defined to bring up your external player.
At the bottom under "Active Transcodings" uncheck the box "mkv > flv"
Click on the Save button.
Once that is done, whenever you use the defined External player to play an .mkv file, it will be sent directly to the external player without being transcoded.
Of course, your external player must be capable of playing .mkv files when you set it up this way. VLC plays just about anything, with WMP yo might need to download codecs.
Postby RaNa » Sun Aug 14, 2011 10:26 pm
umm i just tryed that but vlc
Your input can't be opened:
VLC is unable to open the MRL 'https://192.168.1.100:443/stream?player=1&pathUtf8Hex=443a5c446f776e6c6f6164735c4d6f766965735c417373617373696e73202831393935292e6d6b76&suffix=.mkv'. Check the log for details.
RaNa
Postby GJ51 » Sun Aug 14, 2011 10:50 pm
External players do not play well with https, try the http url or ip address.
I also can't get an externa; player to work in Chrome, only IE.
YMMV
