Performance Issue
Performance Issue
Postby Qbix » Mon Aug 15, 2011 8:38 am
All,
I experience performance issues after a while.
Subsonic installation is running on:
Windows 2003 x64 Enterprise
Dual Xeon 3.2 Ghz
6GB RAM
I tried to solve the performance issue by installing Subsonic (application and web) on a RAM-Drive following this tut: http://forum.subsonic.org/forum/viewtopic.php?t=5707
It was lightning fast but..after a couple of days/weeks it slows down and as I'm typing this message it takes like 25 seconds
before I can see the full web interface. It doesn't matter if I try to load it local or through the internet.
Please advice what to do... :roll:
Cheers,
14.985 artiesten
10.798 albums
90.526 nummers
822,06 GB (~ 12.770 uur)
Qbix
Re: Performance Issue
Postby GJ51 » Mon Aug 15, 2011 6:44 pm
You shouldn't be getting performance issues with the hardware you're running. How long does it take to do a manual index update? What's your file structure?
File structure is the biggest and most frequently seen cause of poor performance, usually when the are too many files/folder.
SS really likes x:\Music\Artist\Album\tracks
Postby alphawave7 » Mon Aug 15, 2011 7:28 pm
Also, inspect your console for used memory...it may be outgrowing your ramdrive capacity (logs?).
