4.5 intermittant connection issues
Postby tnt533 » Fri Aug 19, 2011 4:07 pm
I upgraded to 4.5 two days ago and ever since I have been experiencing connection issues both from the local network and from the internet connecting to my public IP address. I have also had to restart the Subsonic service a few times.
I'm running Subsonic on Linux Mint 11 LMDE on a 2.6 ghz dual core, 8 gig of RAM and over a 10/1 mbps connection.
4.4 ran flawlessly and I had ZERO issues with it.
Anyone else experiencing issues?
tnt533
Re: 4.5 intermittant connection issues
Postby GJ51 » Sat Aug 20, 2011 6:31 am
You might consider expanding the Java memory limit to 256.
Postby tnt533 » Sat Aug 20, 2011 5:01 pm
Sounds like a plan. I am googling but only finding application specific instructions on how to increase the memory available to java. Could you point me in the right direction with either instructions or a link? In the mean time I will keep looking and if I find a solution I will post back in this thread.
tnt533
Postby tnt533 » Sat Aug 20, 2011 5:05 pm
Found the settings in /etc/default/subsonic
I'll report back if it made a difference.
tnt533
Postby GJ51 » Sat Aug 20, 2011 5:11 pm
I'm a Windows user which has a different method for editing the setting, but I know it has been posted for Linix before.
EDIT: This might help:
viewtopic.php?f=6&t=3939
Re: 4.5 intermittant connection issues <SOLVED>
Postby tnt533 » Sat Aug 20, 2011 7:27 pm
Seems to have solved the issues. Thank you for your help.
tnt533
