finding media library
Postby tree » Sat Aug 20, 2011 8:27 pm
I just downloaded latest lite version out of store onto 3gs IPHONE RUNNING THE NEXT TO LATEST VERSION OF 4
64 BIT pc RUNNING WINDOWS 7
SET UP SUBSONIC on pc AND IT DOES not FIND ANY OF MY MEDIA
Name iTunes Music
Folder Z:\BUFFALOBUD\share\My Music\i Tunes
TRIED A SEARCH AND NOTHING COMES UP
TRIED THE NAMES AND Address of itunes folder on my z drive and no luck
just get a no media found? 274 gig library there
any hints
thanks
tree
Re: finding media library
Postby BKKKPewsey » Sat Aug 20, 2011 10:29 pm
Have you read http://monroeworld.com/android/subsonic/ with particular attention to the permissions for shared drive section.
Postby GJ51 » Sun Aug 21, 2011 5:17 am
If Z: is a mapped drive Subsonic will NOT recognize it. Use the UNC to the share and edit the logon for the subsonic service in windows as described in the link in the post below.
You will also have touble if your media is all in a defined path in subsonic without being placed in folders.
e.g. X:\music = defined path in Settings/Music Folders and all the tracks are just in the \music directory
Subsonic likes the music organized into:
X:\Music\Artist\Album\Tracks
So the Settings/Music folder would be
X:\Music
and then SS would display all the Artist folders in the left column.
If tracks are just placed in the root of a defined folder, then the tracks will appear in the left column on the desktop but will not appear on a phone app because it won't see any folders.
