Help: no ape files shown
Postby Dip » Sat Aug 27, 2011 9:07 pm
i'm new here, so please forgive me, when i ask something which is obvious for you. But i really tried to find an answer for my problem in this forum here.
I've got a music library, where most files are ape files (single files). I figured out to get subsonic up and running on a Mac Mini 10.5, MacBook Pro 10.6 and a Windows XP PC (standalone and application). I can see in the browser and and i can stream mp3 and flac files. But whatever i do i can't see any of my ape files in the album's track list. But i can transcode them in the command line with ffmpeg.
Can anyone help me?
Technical infos:
My music library:
1.738 folder
858 mp3 files
34.102 ape files
1.141 flac files
2.349 jpg files
821 GB data
folder structure:
Artist/Album/tracks
or
Artist/tracks
Problem Description and troubleshooting:
It seems, that my mac installations of subsonic are not able to parse my .ape files.
I can see and play any albums and tracks in flac and mp3 format but the server does not see any tracks of my albums containing ape files.
Beginning with the index frame (left hand side frame in the browser) my client shows:
173 artists
507 albums
2,042 songs
66.57 GB (~ 1,034 hours)
Below it shows the alphabetical list of the albums which contains approx. 1.600 albums (or more), so here is the first place where i can see that somethings is wrong on the server side. If i add the numbers found by "find . -name '*.mp3' -type f | wc -l" and "find . -name '*.flac' -type f | wc -l" i do get 2006 songs, which is close to 2.042 found by the subsonic server. But i'm missing more than 34.000 ape files. If i click in the list on an album containing mp3 or flac files the frame on the right shows the track list and clicking on a track regardless if it is mp3 or flac the player starts playing. But if i click on an album containing ape files no tracks are shown, only the cover art (the log file says nothing in this moment).
Because the transcoding and the player is working for flac files and the transcoding for ape files by hand in the terminal works fine (see below) it seems to be a problem on the server side parsing the ape files. To eliminate the PPC Mac as the problem i tried an installation on a MacBook Pro with the same result, not showing any ape files. To be sure i started indexing several times by hand which says:
[2011-08-27 13:36:22,782] INFO SearchService - Starting to create search index.
[2011-08-27 13:36:27,225] INFO SearchService - Created search index with 1000 entries.
[2011-08-27 13:36:28,970] INFO SearchService - Created search index with 2000 entries.
[2011-08-27 13:36:31,789] INFO SearchService - Created search index with 3000 entries.
[2011-08-27 13:36:34,758] INFO SearchService - Created search index with 4000 entries.
[2011-08-27 13:36:40,424] INFO SearchService - Created search index with 5000 entries.
[2011-08-27 13:36:44,605] INFO SearchService - Created search index with 6000 entries.
[2011-08-27 13:36:47,423] INFO SearchService - Updating Lucene search index.
[2011-08-27 13:36:48,826] INFO SearchService - Created search index with 6667 entries.
Wherever the number of 6.667 comes from, it doesn't seem to be quite right.
Playback Application and version:
JW Player 5.6.1768 (default bundled subsonic browser player)
Subsonic Version:
Mac Mini: 4.5 (build 2384) – August 10, 2011
MacBook Pro: 4.5 (build 2384) – August 10, 2011
Server Version:
Mac Mini: (Standalone because installer doesn't work on PPC) jetty-6.1.x, java 1.5.0_30, Mac OS X (26.3 MB / 44.9 MB)
MacBook Pro: jetty-6.1.x, java 1.6.0_26, Mac OS X (41.3 MB / 81.1 MB)
Hardware Platform:
Mac Mini G4 PPC, 1,5 GHz, 1GB RAM, Mac OS X 10.5.8 Server
MacBook Pro Intel Core 2 Duo 2,53 GHz, 4 GB RAM, Mac OS X 10.6.8
Java Memory Limit:
Don't know where to find on a Mac.
Output from ffmpeg -i:
For my Mac Mini i first tried to copy the ffmpeg and lame binaries out of /Library/Application Support/Subsonic/transcode into /var/subsonic/transcode but figured out, that this binaries are no fat binaries and do not run on my PPC with Mac OS X 10.5. So i downloaded fat versions from the internet (i can't remember but i believe it was http://ffmpegmac.net/ and http://www.thalictrum.com/software/LAME ... 0.2.dmg.gz).
Mac Mini:
sh-3.2# ./ffmpeg -i abba.ape -f wav - > abba.wav
ffmpeg version 0.8, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 19 2011 17:18:36 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --prefix=/Volumes/Ramdisk/sw --enable-gpl --enable-pthreads --enable-version3 --enable-libspeex --enable-libvpx --disable-decoder=libvpx --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-avfilter --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-filters --arch=ppc --enable-runtime-cpudetect
  libavutil    51.  9. 1 / 51.  9. 1
  libavcodec   53.  7. 0 / 53.  7. 0
  libavformat  53.  4. 0 / 53.  4. 0
  libavdevice  53.  1. 1 / 53.  1. 1
  libavfilter   2. 23. 0 /  2. 23. 0
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Input #0, ape, from 'abba.ape':
  Metadata:
    Track           : 16
    Year            : 1994
    Genre           : Rock
    Artist          : Abba
    Title           : Dancing Queen
    Tool Version    : 13.0.171
    Tool Name       : Media Center
    Comment         : Exact Audio Copy
    Media Jukebox: Date: 34335
    Album           : Thank You For The Music (CD 1)
    Cover Art (front): C:\Dokumente und Einstellungen\dip\Anwendungsdaten\J River\Media Center 13\Cover Art\Abba - Thank You For The Music (CD 1).jpg
  Duration: 00:03:50.71, start: 0.000000, bitrate: 1010 kb/s
    Stream #0.0: Audio: ape, 44100 Hz, stereo, s16
Output #0, wav, to 'pipe:':
  Metadata:
    Track           : 16
    Year            : 1994
    Genre           : Rock
    Artist          : Abba
    encoder         : Lavf53.4.0
    Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
Press [q] to stop, [?] for help
Multiple frames in a packet from stream 0
size=   39752kB time=00:03:50.76 bitrate=1411.2kbits/s
video:0kB audio:39752kB global headers:0kB muxing overhead 0.000108%
MacBook Pro (ffmpeg binary from /Library/Application Support/Subsonic/transcode):
IT526-2:transcode dip$ ./ffmpeg -i abba.ape -f wav - > abba.wav
FFmpeg version SVN-r25203-einsteinx2, Copyright (c) 2000-2010 the FFmpeg developers
  built on Sep 26 2010 02:08:29 with gcc 4.2.1 (Apple Inc. build 5664)
  configuration: --prefix=/Volumes/Ramdisk/ --as=yasm --extra-version=einsteinx2 --disable-shared --enable-static --disable-ffplay --disable-ffserver --enable-gpl --enable-pthreads --enable-postproc --enable-gray --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-libspeex --enable-bzlib --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-nonfree --enable-version3
  libavutil     50.28. 0 / 50.28. 0
  libavcore      0. 9. 0 /  0. 9. 0
  libavcodec    52.90. 0 / 52.90. 0
  libavformat   52.78. 5 / 52.78. 5
  libavdevice   52. 2. 2 / 52. 2. 2
  libavfilter    1.45. 0 /  1.45. 0
  libswscale     0.11. 0 /  0.11. 0
  Metadata:
    Track           : 1
    Year            : 1994
    Genre           : Rock
    Artist          : Abba
    Title           : People Need Love
    Album           : Thank You for the Music (CD 1)
    Cover Art (front): C:\Dokumente und Einstellungen\dip\Anwendungsdaten\J River\Media Center 13\Cover Art\Abba - Thank You for the Music (CD 1).jpg
  Duration: 00:02:46.55, start: 0.000000, bitrate: 885 kb/s
  Metadata:
    encoder         : Lavf52.78.5
Stream mapping:
  Stream #0.0 -> #0.0
Press [q] to stop encoding
size=   28704kB time=166.63 bitrate=1411.2kbits/s
video:0kB audio:28704kB global headers:0kB muxing overhead 0.000150%
Log file lines:
Log for successfully streaming a flac file
[2011-08-27 13:24:06,656] INFO PlaylistInputStream - linus listening to "Rumours/(01) Second Hand News.flac"
[2011-08-27 13:24:06,905] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/Volumes/audio-001/Fleetwood Mac/Rumours/(01) Second Hand News.flac] [-v] [0] [-f] [wav] [-]
[2011-08-27 13:24:06,963] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [--tt] [Second Hand News] [--ta] [Fleetwood Mac] [--tl] [Rumours] [-S] [--resample] [44.1] [-] [-]
[2011-08-27 13:24:07,070] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version 0.8, Copyright (c) 2000-2011 the FFmpeg developers
[2011-08-27 13:24:07,072] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Jul 19 2011 17:18:36 with gcc 4.0.1 (Apple Inc. build 5493)
[2011-08-27 13:24:07,072] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/Volumes/Ramdisk/sw --enable-gpl --enable-pthreads --enable-version3 --enable-libspeex --enable-libvpx --disable-decoder=libvpx --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-avfilter --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-filters --arch=ppc --enable-runtime-cpudetect
[2011-08-27 13:24:07,072] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51.  9. 1 / 51.  9. 1
[2011-08-27 13:24:07,072] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  7. 0 / 53.  7. 0
[2011-08-27 13:24:07,073] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  4. 0 / 53.  4. 0
[2011-08-27 13:24:07,073] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  1. 1 / 53.  1. 1
[2011-08-27 13:24:07,073] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 23. 0 /  2. 23. 0
[2011-08-27 13:24:07,073] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2011-08-27 13:24:07,073] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2011-08-27 13:24:07,544] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [flac @ 0x1001c00] max_analyze_duration 5000000 reached at 5015510
[2011-08-27 13:24:07,545] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/Volumes/audio-001/Fleetwood Mac/Rumours/(01) Second Hand News.flac':
[2011-08-27 13:24:07,545] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2011-08-27 13:24:07,545] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TOOL NAME       : Media Center
[2011-08-27 13:24:07,545] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TOOL VERSION    : 13.0.171
[2011-08-27 13:24:07,545] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     REPLAY GAIN     : -9,9302399999999996
[2011-08-27 13:24:07,547] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     PEAK LEVEL      : 1
[2011-08-27 13:24:07,548] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     track           : 1
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ARTIST          : Fleetwood Mac
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     BPM             : 117
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ALBUM           : Rumours
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TITLE           : Second Hand News
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     GENRE           : Pop
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     INTENSITY       : 2
[2011-08-27 13:24:07,549] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     DATE            : 1977
[2011-08-27 13:24:07,550] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     JR_DATE         : 28126
[2011-08-27 13:24:07,550] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:02:53.66, bitrate: 882 kb/s
[2011-08-27 13:24:07,550] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[2011-08-27 13:24:07,559] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TOOL NAME       : Media Center
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TOOL VERSION    : 13.0.171
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     REPLAY GAIN     : -9,9302399999999996
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     PEAK LEVEL      : 1
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     track           : 1
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ARTIST          : Fleetwood Mac
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     BPM             : 117
[2011-08-27 13:24:07,560] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ALBUM           : Rumours
[2011-08-27 13:24:07,561] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TITLE           : Second Hand News
[2011-08-27 13:24:07,561] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     GENRE           : Pop
[2011-08-27 13:24:07,561] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     INTENSITY       : 2
[2011-08-27 13:24:07,562] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     DATE            : 1977
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     JR_DATE         : 28126
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     encoder         : Lavf53.4.0
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2011-08-27 13:24:07,563] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2011-08-27 13:24:24,870] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   29917kB time=00:02:53.66 bitrate=1411.2kbits/s
[2011-08-27 13:24:24,871] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) video:0kB audio:29917kB global headers:0kB muxing overhead 0.000144%
[2011-08-27 13:24:24,904] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) fatal error: can't update LAME-tag frame!
Log during startup:
[2011-08-26 21:03:22,349] INFO DaoHelper - Checking database schema.
[2011-08-26 21:03:23,985] INFO DaoHelper - Done checking database schema.
[2011-08-26 21:03:24,829] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Aug 27 01:00:00 CEST 2011
[2011-08-26 21:03:25,397] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Aug 26 21:08:25 CEST 2011
[2011-08-26 21:03:28,025] WARN NetworkService - Failed to find UPnP router using WeUPnP library.
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
        at java.lang.String.substring(String.java:1768)
        at org.wetorrent.upnp.GatewayDiscover.parseMSearchReplay(GatewayDiscover.java:175)
        at org.wetorrent.upnp.GatewayDiscover.discover(GatewayDiscover.java:130)
        at net.sourceforge.subsonic.domain.WeUPnPRouter.findRouter(WeUPnPRouter.java:39)
        at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.findRouter(NetworkService.java:197)
        at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:132)
        at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:417)
        at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:280)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:135)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:65)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(ScheduledThreadPoolExecutor.java:146)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:170)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:651)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:676)
        at java.lang.Thread.run(Thread.java:655)
[2011-08-26 21:05:14,280] INFO VersionService - Resolved local Subsonic version to: 4.5
[2011-08-26 21:05:14,552] INFO VersionService - Resolved latest Subsonic final version to: 4.5
[2011-08-26 21:05:14,553] INFO VersionService - Resolved latest Subsonic beta version to: 4.5.beta2
Dip
Re: Help: no ape files shown
Postby BKKKPewsey » Sat Aug 27, 2011 9:22 pm
Have you selected ape within the music mask (Settings/General) ?
(A short reply to a long post :) )
Postby Dip » Sun Aug 28, 2011 8:21 am
:oops:
Thank's, it works now.
Dip
Users browsing this forum: No registered users and 50 guests
