Update windows version
Postby pedro666 » Sun Aug 28, 2011 6:31 pm
Every time that I do a upgrade of the Windows stand alone version i loos all the setting. Can't find a way to do that without losing all my settings. Look around on the forum but can't find e solution. Help???
pedro666
Re: Update windows version
Postby BKKKPewsey » Mon Aug 29, 2011 3:24 am
If you are using the windows installer you shouldn't lose your data if you just install over the old version. However if you are using the stand alone package I would suggest making a backup of subsonic.script within the db folder.
This is where the users / music folders /other settings are stored. If you stop SS replaced the new file with the backup you should retain your settings.
Hopefully someone will confirm what I suggest will actually work :mrgreen:
