Mac Subsonic Standalone + https?
Postby bass_rock » Thu Sep 01, 2011 10:44 pm
Can someone give me some help on how to set up the standalone mac subsonic to use https?
bass_rock
Re: Mac Subsonic Standalone + https?
Postby BinaryBuddha » Mon Sep 19, 2011 10:23 pm
Look at the bottom of this page...
http://www.subsonic.org/pages/getting-started.jsp
I don't have Mac so i can't tell you where the configuraiton file is stored.
Supposedly, if Mac's truely are Unix based you should be able to find the file using this in the commandline interface.
find / -type f -iname "subsonic"
You also might be able to find the basic directories that SS stores it's configuration files with this one.
find / -type d -iname "*subsonic*"
BinaryBuddha
