Subsonic Transcodes Same Song Multiple Times
Postby musicmancm » Thu Sep 08, 2011 1:02 am
Any help on the below problem is greatly appreciated.
Problem Description: After creating a new music playlist, Subsonic is transcoding the initial song in the playlist multiple times before succeeding and moving on the the next song. Songs following the initial song seem to work fine - they get transcoded once and the Android player downloads the song, except if the player is left alone for a while and I come back and the next song to be downloaded is triggered (the current song ends or I skip to the next song). I've seen it transcode the first song 2-4 times in a row before moving on to the next.
Troubleshooting steps: The transcode executable that I'm running is a compiled Perl script (included in code block at the bottom of my post, hopefully I don't have a bug there) which works fine outside of Subsonic - it converts MP3's to WAV's to M4A's. It also works fine within Subsonic - all temp files get created as they should, Subsonic just runs the transcode multiple times as described in the problem description. I've tried putting some "sleeps" in the script at various places to account for any type of timing issue to no avail. I've tried to pipe all STDERR output to nul thinking that something was getting read in by Subsonic that shouldn't. I actually am getting an error message in FFMPEG, but I get it with normal operation even with MP3's that get transcoded successfully once - it's a "Missing MP3 header" error. I say again, I get this even when things work normally, and even when I run FFMPEG outside of Subsonic - my source MP3's were all encoded with LAME, (DLL downloaded from a link off of Audiograbber's website). FFMPEG is tripping up over something, I don't know what, but it's doesn't affect the sound of the final M4A file that I can tell. All that said, I don't thing this error message is causing an issue. Other than these things I've tried, I don't know how Subsonic works internally so I don't know what else to look at.
Playback application and version: Android app V3.1
Subsonic Version: 4.4 (build 2172) – February 6, 2011
jetty-6.1.x, java 1.6.0_18, Windows XP (32.5 MB / 47.6 MB)
Hardware Platform: Windows XP, all latest Service Packs and updates
Java Memory Limit: 100 megs (I haven't seen used memory go above 60 megs)
Problem Filename: NA
Output from ffmpeg -i:
C:\subsonic\transcode>ffmpeg.exe -i "C:\Utility\Music Files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3"
FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
  built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
  libavutil     50. 7. 0 / 50. 7. 0
  libavcodec    52.47. 0 / 52.47. 0
  libavformat   52.47. 0 / 52.47. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.15. 0 /  1.15. 0
  libswscale     0. 8. 0 /  0. 8. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mp3 @ 0133cd80]max_analyze_duration reached
[mp3 @ 0133cd80]Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'C:\Utility\Music Files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3':
  Metadata:
    TIT2            : Green Onions
    TALB            : The Best Of Booker T. & The M.G.'s
    TPE1            : Booker T. & The M.G.'s
    TCON            : R&B
    TYER            : 1984
    TRCK            : 1/16
    TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
  Duration: 00:02:58.82, start: 0.000000, bitrate: 192 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
Last log file lines: (I'm including from the beginning of my playlist I created, you can see the first song "Green Onions" is transcoded three times)
[2011-09-07 19:14:15,156] INFO VersionService - Resolved local Subsonic version to: 4.4
[2011-09-07 19:14:15,359] INFO VersionService - Resolved latest Subsonic final version to: 4.5
[2011-09-07 19:14:15,359] INFO VersionService - Resolved latest Subsonic beta version to: 4.5.beta2
[2011-09-07 19:31:03,109] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3"
[2011-09-07 19:31:03,140] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Green Onions]
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]max_analyze_duration reached
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3':
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Green Onions
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 1/16
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:58.82, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp93322753.wav':
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f570]Header missing
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:31:08,562] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   30047kB time=174.42 bitrate=1411.2kbits/s
[2011-09-07 19:31:09,078] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:31:09,078] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:30046kB global headers:0kB muxing overhead 0.000143%
[2011-09-07 19:31:15,125] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3"
[2011-09-07 19:31:15,140] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Green Onions]
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]max_analyze_duration reached
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3':
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Green Onions
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 1/16
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:58.82, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp527587890.wav':
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f570]Header missing
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:31:17,890] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   30047kB time=174.42 bitrate=1411.2kbits/s
[2011-09-07 19:31:18,687] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:31:18,687] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:30046kB global headers:0kB muxing overhead 0.000143%
[2011-09-07 19:31:27,828] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3"
[2011-09-07 19:31:27,859] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Green Onions]
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]max_analyze_duration reached
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2a0]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Green Onions.mp3':
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Green Onions
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 1/16
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:58.82, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp30517.wav':
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f570]Header missing
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:31:30,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   30047kB time=174.42 bitrate=1411.2kbits/s
[2011-09-07 19:31:31,187] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:31:31,187] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:30046kB global headers:0kB muxing overhead 0.000143%
[2011-09-07 19:31:53,640] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Mo' Onions.mp3"
[2011-09-07 19:31:53,671] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Mo' Onions.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Mo' Onions]
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]max_analyze_duration reached
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Mo' Onions.mp3':
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Mo' Onions
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 2/16
[2011-09-07 19:31:58,296] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:03:00.18, start: 0.000000, bitrate: 191 kb/s
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp298675537.wav':
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f560]Header missing
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:31:58,312] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   30281kB time=175.78 bitrate=1411.2kbits/s
[2011-09-07 19:31:58,546] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:31:58,546] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:30280kB global headers:0kB muxing overhead 0.000142%
[2011-09-07 19:32:23,640] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Jellybread.mp3"
[2011-09-07 19:32:23,656] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Jellybread.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Jellybread]
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]max_analyze_duration reached
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Jellybread.mp3':
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Jellybread
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 3/16
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:35.12, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp789123535.wav':
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f560]Header missing
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:32:26,671] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   25965kB time=150.73 bitrate=1411.2kbits/s
[2011-09-07 19:32:27,578] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:32:27,578] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:25965kB global headers:0kB muxing overhead 0.000165%
[2011-09-07 19:32:48,734] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Tic-Tac-Toe.mp3"
[2011-09-07 19:32:48,750] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Tic-Tac-Toe.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Tic-Tac-Toe]
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]max_analyze_duration reached
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e290]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Tic-Tac-Toe.mp3':
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Tic-Tac-Toe
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 4/16
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:39.38, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp756286621.wav':
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f560]Header missing
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:32:52,812] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   26699kB time=154.98 bitrate=1411.2kbits/s
[2011-09-07 19:32:52,859] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:32:52,859] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:26698kB global headers:0kB muxing overhead 0.000161%
[2011-09-07 19:33:18,812] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Soul Dressing.mp3"
[2011-09-07 19:33:18,843] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Soul Dressing.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Soul Dressing]
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2b0]max_analyze_duration reached
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2b0]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Soul Dressing.mp3':
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Soul Dressing
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 5/16
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:37.11, start: 0.000000, bitrate: 191 kb/s
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp835540771.wav':
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f580]Header missing
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:33:22,796] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   26307kB time=152.71 bitrate=1411.2kbits/s
[2011-09-07 19:33:22,906] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:33:22,906] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:26307kB global headers:0kB muxing overhead 0.000163%
[2011-09-07 19:33:48,859] INFO PlaylistInputStream - chad listening to "The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Terrible Thing.mp3"
[2011-09-07 19:33:48,890] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\mp3tomp4] [64] [c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Terrible Thing.mp3] [Booker T. & The M.G.'s] [The Best Of Booker T. & The M.G.'s] [Terrible Thing]
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavutil     50. 7. 0 / 50. 7. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavcodec    52.47. 0 / 52.47. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavformat   52.47. 0 / 52.47. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libavfilter    1.15. 0 /  1.15. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libswscale     0. 8. 0 /  0. 8. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2b0]max_analyze_duration reached
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133e2b0]Estimating duration from bitrate, this may be inaccurate
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Input #0, mp3, from 'c:\utility\Music files\MP3s\Booker T. & The M.G.'s\The Best Of Booker T. & The M.G.'s\Booker T. & The M.G.'s - Terrible Thing.mp3':
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Metadata:
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TIT2            : Terrible Thing
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TALB            : The Best Of Booker T. & The M.G.'s
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TPE1            : Booker T. & The M.G.'s
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TCON            : R&B
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TYER            : 1984
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TRCK            : 6/16
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     TSSE            : Audiograbber 1.83.01, LAME dll 3.98, 192 Kbit/s, Joint Stereo, High quality
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Duration: 00:02:39.70, start: 0.000000, bitrate: 192 kb/s
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 192 kb/s
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Output #0, wav, to 'c:\subsonic\transcode\temp822570800.wav':
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Stream mapping:
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)   Stream #0.0 -> #0.0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Press [q] to stop encoding
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) [mp3 @ 0133f580]Header missing
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) Error while decoding stream #0.0
[2011-09-07 19:33:51,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) size=   26753kB time=155.30 bitrate=1411.2kbits/s
[2011-09-07 19:33:52,765] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4)
[2011-09-07 19:33:52,765] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\mp3tomp4) video:0kB audio:26752kB global headers:0kB muxing overhead 0.000161%
Additional Info - my transcode executable (complied Perl script):
my $home = "c:\\subsonic\\transcode";
my ($bitrate,$inFile,$artist,$album,$title) = (@ARGV);
my $filerand = int(rand(1000000000));
if ($bitrate != 32 and $bitrate != 40 and $bitrate != 48 and $bitrate != 56 and $bitrate != 64 and $bitrate != 80) {
   $bitrate = 80;
`\"$home\\ffmpeg\" -i \"$inFile\" -v 0 -f wav \"$home\\temp$filerand.wav\"`;
sleep 1;
`\"$home\\qaac\" \"$home\\temp$filerand.wav\" --silent --he -a $bitrate -o \"$home\\temp$filerand.m4a\" --artist \"$artist\" --album \"$album\" --title \"$title\"`;
sleep 1;
unlink "$home\\temp$filerand.wav";
open(IN,"<$home\\temp$filerand.m4a");
binmode IN;
binmode STDOUT;
while (<IN>) {
   print $_;
close IN;
unlink "$home\\temp$filerand.m4a";
Additional Info - my transcode in Subsonic (single Stage, enabled under Transcode and my user):
mp3 > m4a - mp3 - m4a - mp3tomp4 %b %s %a %l %t
musicmancm
