Weird intermittant issues since upgrade
Postby liquiddiet » Thu Sep 08, 2011 12:50 pm
I cant figure out what is going on with my subsonic server. I recently got a new router and upgraded my subsonic to 4.5 (build 2385) – August 11, 2011 at the same time. I setup port forwarding and it worked fine, but it behaves very erratic. i can be streaming music and when i go to change albums it doesnt load correctly. I reload page and i get this:
reload..same thing, reload, reload, reload, give up.
i try in 15 min and everything is back to normal. I cant figure it out, any ideas?
liquiddiet
Re: Weird intermittant issues since upgrade
Postby BKKKPewsey » Thu Sep 08, 2011 1:09 pm
Do you get the same problem with chrome or IE?
And what version of FF are you running? It could be due to one of the very frequent FF updates.
Postby liquiddiet » Thu Sep 08, 2011 1:18 pm
It does not work in Chrome or IE either
IE:
Chrome:
liquiddiet
Postby liquiddiet » Thu Sep 08, 2011 1:22 pm
and iSub
liquiddiet
Postby BKKKPewsey » Thu Sep 08, 2011 1:48 pm
Ok next question what port are you using?
Postby liquiddiet » Thu Sep 08, 2011 2:07 pm
Port 80
liquiddiet
Postby BKKKPewsey » Thu Sep 08, 2011 3:46 pm
OK change the subsonic port to something else say 8080 and I suggest you read http://monroeworld.com/android/subsonic/
Port 80 is used by other services so they are all fighting over the same real estate :lol:
Don't forget to forward the new port in the router!
Postby liquiddiet » Tue Sep 13, 2011 2:08 pm
Same issue on 8080 very strange
liquiddiet
