Lost Saved Data After Upgrade
Postby rjbrooksjr » Fri Sep 09, 2011 5:18 pm
Hi Everyone - I just upgraded from 4.4 to 4.5, and it seems to have wiped out all my data. Users, saved folders, and most importantly (to me) my stats on most played songs that I live in ALL day. Is there any way I can recover this, or is it lost forever?
Version 4.5 (build 2385) – August 11, 2011
Server jetty-6.1.x, java 1.6.0_23, Windows Server 2008 R2 (12.1 MB / 15.6 MB)
Thanks.
rjbrooksjr
Re: Lost Saved Data After Upgrade
Postby BKKKPewsey » Fri Sep 09, 2011 10:45 pm
It certainly should not have wiped your data. Have you checked that SS installed in the same location as before.
The user data is stored in db\subsonic.script so have a look to see if you have 2 copies and in future if you backup that file before upgrading you should be ok.
Postby rjbrooksjr » Mon Sep 12, 2011 4:18 pm
Good suggestion, but it did install in the same place and I only have one subsonic.script file. That's a pretty huge bummer.
Thanks.
rjbrooksjr
