Unable to connect to Subsonic...
Postby magnusoverli » Fri Sep 09, 2011 11:57 pm
Hi guys!
First of all, thank you!! From the bottom of my heart, THANK YOU! Since I discovered Subsonic, it has made my (music-)life problemless! Untill now that is..
My problem is that I suddenly cannot connect to my Subsonic server. This came over the night, and I have no idea what happened! I have the latest version installed, and a license registered. It runs on a Ubuntu Server 11.04 x64 with all current updates installed, and latest official kernel.
After this problem occurred, I have uninstalled and reinstalled subsonic, as well as openjdk. When doing a "sudo service subsonic start" I get a PID number and a notification that subsonic is running. I have other services that I can connect to without problems, such as ssh and transmission.
I would really like some help trying to figure this out, as I am completely out of ideas on where to look next....
In advance, thank for any help!
Magnus
My logs:
[2011-09-09 20:25:04,969] INFO DaoHelper - Checking database schema.
[2011-09-09 20:25:05,089] INFO Schema25 - Database table 'version' not found. Creating it.
[2011-09-09 20:25:05,096] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLo$
[2011-09-09 20:29:13,276] INFO PodcastService - Completed scheduled Podcast refresh.
[2011-09-09 21:24:19,211] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-09 22:24:22,262] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-09 23:24:25,320] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-10 00:24:28,375] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-10 01:24:31,468] INFO NetworkService - Successfully forwarding port 4040.
aoHelper.<init>(DaoHelper.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
Caused by: java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@2d6451a6[file =/var/subsonic/db/subsonic.lck, exists=true, locked=false, valid=false, fl =nu$
at java.sql.DriverManager.getConnection(DriverManager.java:620)
at java.sql.DriverManager.getConnection(DriverManager.java:169)
... 76 more
[2011-09-09 20:25:05,382] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Sep 10 03:00:00 CEST 2011
[2011-09-09 20:25:08,470] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-09 21:25:11,529] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-09 22:25:14,590] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-09 23:25:17,632] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-10 00:25:20,685] INFO NetworkService - Successfully forwarding port 4040.
[2011-09-10 01:25:23,740] INFO NetworkService - Successfully forwarding port 4040.
magnusoverli
Re: Unable to connect to Subsonic...
Postby magnusoverli » Sat Sep 10, 2011 12:03 am
UPDATE: I tried to change the port Subsonic listens to from 4040 to 34555. When trying to connect I now get the following response:
HTTP ERROR 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
magnusoverli
Postby BKKKPewsey » Sat Sep 10, 2011 3:27 am
Have you tried a clean install?
Delete your subsonic folder then re-install BUT remember that will delete all your settings eg. users, licence etc.
You could try to delete all within the \db directory except subsonic.script which may save your settings but no guarantees :roll:
Postby magnusoverli » Sat Sep 10, 2011 9:34 am
Hi, and thanks for answering! :-)
Now I have tried to first uninstall Subsonic with "apt-get autoremove subsonic", and then identifying any leftovers with "locate subsonic"... I then deleted any file and/or folder related to subsonic. After this I downloaded and installed subsonic from the start. Still same result. Still getting Webpage not available... The server is in a remote location, but set up as a dmz, and as I said, all other services are connectable....
Please help? ;-)
Magnus
magnusoverli
Postby hexapus » Sat Sep 10, 2011 12:42 pm
EXACT same problem here. Running Debian Sid. Updated to latest version, Subsonic looks like it's running happily, no errors in the log, but I can't connect to it, either from outside or from the machine itself using localhost. I have it running on port 4040, and everything but subsonic is working fine. Even tried downgrading back to 4.4, but no dice! :?
hexapus
Postby magnusoverli » Sat Sep 10, 2011 5:14 pm
Anyone with any tips on how to solve this?
magnusoverli
Postby ChiMatt » Sat Sep 10, 2011 7:33 pm
I am getting the same error. No issues connecting from a remote location with tightvnc or other remote programs. Used to be able to connect remotely with subsonic. installed latest version. Can connect locally to subsonic through tightvnc on local computer. Have registered subsonic.org domain name and version. Port says it is forwarded properly and a successfully registered web address, but the site does not resolve as it should. I have tried reinstalling back to a previous version but might try that unless someone has am alternative solution. This looks to be new with latest release from what I can tell. Thoughts?
ChiMatt
Postby magnusoverli » Sat Sep 10, 2011 7:52 pm
What system are you running ChiMatt? Ubuntu/Debian as well? Has there been any recent updates to any dependencies that Subsonic rely on? I have been using Subsonic for some time without problems, also the 4.5 version... But maybe thare has been other changes that makes Subsonic malfunction on an Ubuntu/Debian-system?
Are you guys also 64bit? Do you have all updates installed? Any recent changes to the java installation?
Can you think of any other dependencies or system specific changes that may be relevant?
Glad, so to say, that I´m not alone in this! ;-)
Magnus
Update: I have notifyed Sindre about this thread.... Let´s hope he has time/interest enough to have a look! :-)
magnusoverli
Postby magnusoverli » Sat Sep 10, 2011 7:57 pm
Just a thought.... Do you guys have Port Forwarding enabled? I mean the upnp setting within Subsonic?
magnusoverli
Postby hexapus » Sun Sep 11, 2011 3:06 am
I'm running debian 64-bit, and yes, I'd just recently apt-get upgraded the packages on my machine, so java might have been included in that. I then downloaded the 4.5 .deb package and installed that. After that, it refused to connect either remotely or on localhost. I tried using the IP directly, the hostname, as well as hitting localhost via lynx and opening firefox directly on the server by way of a vnc session. No dice. No idea if the upnp stuff is set up...which config file would I find that in?
Let me know what else I could provide to help troubleshoot. Subsonic is kinda my primary access to my media, so I miss it! :-)
hexapus
Postby sindre_mehus » Sun Sep 11, 2011 7:36 am
You have to look in the log files (in /var/subsonic) for diagnosis.
For example, the problem described in the original post by Magnus is either:
a) Two instances of Subsonic running.
b) Obsolete lock file (/var/subsonic/db/subsonic.lck)
Make sure Subsonic is not running, delete the lock file and try again.
Hope this helps,
Postby magnusoverli » Sun Sep 11, 2011 7:51 am
Hi Sindre!
Thanks for the input here.
I just cd´ed into /var/subsonic/db/ but there is no .lck-file there. Could it be in another folder?
Which of the logs (subsonic.log/subsonic_sh.log) is the most interesting one?
Also, I´m no expert, but it looks to me as there is only one instance of Subsonic running... How can I confirm this?
Magnus
Update: This is my subsonic.log and I cannot find any errors...
[2011-09-10 11:29:15,849] INFO DaoHelper - Checking database schema.
[2011-09-10 11:29:16,375] INFO Schema25 - Database table 'version' not found. Creating it.
[2011-09-10 11:29:16,389] INFO Schema25 - Database table 'version' was created successfully.
[2011-09-10 11:29:16,389] INFO Schema25 - Database table 'role' not found. Creating it.
[2011-09-10 11:29:16,391] INFO Schema25 - Database table 'role' was created successfully.
[2011-09-10 11:29:16,391] INFO Schema25 - Database table 'user' not found. Creating it.
[2011-09-10 11:29:16,392] INFO Schema25 - Database table 'user' was created successfully.
[2011-09-10 11:29:16,392] INFO Schema25 - Database table 'user_role' not found. Creating it.
[2011-09-10 11:29:16,407] INFO Schema25 - Database table 'user_role' was created successfully.
[2011-09-10 11:29:16,414] INFO Schema26 - Updating database schema to version 2.
[2011-09-10 11:29:16,414] INFO Schema26 - Database table 'music_folder' not found. Creating it.
[2011-09-10 11:29:16,415] INFO Schema26 - Database table 'music_folder' was created successfully.
[2011-09-10 11:29:16,415] INFO Schema26 - Database table 'music_file_info' not found. Creating it.
[2011-09-10 11:29:16,582] INFO Schema26 - Database table 'music_file_info' was created successfully.
[2011-09-10 11:29:16,582] INFO Schema26 - Database table 'internet_radio' not found. Creating it.
[2011-09-10 11:29:16,582] INFO Schema26 - Database table 'internet_radio' was created successfully.
[2011-09-10 11:29:16,583] INFO Schema26 - Database table 'player' not found. Creating it.
[2011-09-10 11:29:16,583] INFO Schema26 - Database table 'player' was created successfully.
[2011-09-10 11:29:16,584] INFO Schema26 - Database column 'player.dynamic_ip' not found. Creating it.
[2011-09-10 11:29:16,584] INFO Schema26 - Database column 'player.dynamic_ip' was added successfully.
[2011-09-10 11:29:16,585] INFO Schema26 - Role 'comment' not found in database. Creating it.
[2011-09-10 11:29:16,596] INFO Schema26 - Role 'comment' was created successfully.
[2011-09-10 11:29:16,597] INFO Schema27 - Updating database schema to version 3.
[2011-09-10 11:29:16,597] INFO Schema27 - Converting database column 'music_file_info.path' to varchar_ignorecase.
[2011-09-10 11:29:16,598] INFO Schema27 - Database column 'music_file_info.path' was converted successfully.
[2011-09-10 11:29:16,599] INFO Schema27 - Database columns 'user.bytes_streamed/downloaded/uploaded' not found. Creating them.
[2011-09-10 11:29:16,599] INFO Schema27 - Database columns 'user.bytes_streamed/downloaded/uploaded' were added successfully.
[2011-09-10 11:29:16,600] INFO Schema28 - Updating database schema to version 4.
[2011-09-10 11:29:16,600] INFO Schema28 - Database table 'user_settings' not found. Creating it.
[2011-09-10 11:29:16,602] INFO Schema28 - Database table 'user_settings' was created successfully.
[2011-09-10 11:29:16,602] INFO Schema28 - Database table 'transcoding' not found. Creating it.
[2011-09-10 11:29:16,605] INFO Schema28 - Database table 'transcoding' was created successfully.
[2011-09-10 11:29:16,605] INFO Schema28 - Database table 'player_transcoding' not found. Creating it.
[2011-09-10 11:29:16,606] INFO Schema28 - Database table 'player_transcoding' was created successfully.
[2011-09-10 11:29:16,606] INFO Schema29 - Updating database schema to version 5.
[2011-09-10 11:29:16,607] INFO Schema29 - Database table 'user_rating' not found. Creating it.
[2011-09-10 11:29:16,607] INFO Schema29 - Database table 'user_rating' was created successfully.
[2011-09-10 11:29:16,608] INFO Schema29 - Migrated data from 'music_file_info' to 'user_rating'.
[2011-09-10 11:29:16,608] INFO Schema30 - Updating database schema to version 6.
[2011-09-10 11:29:16,609] INFO Schema30 - Database columns 'user_settings.last_fm_*' not found. Creating them.
[2011-09-10 11:29:16,610] INFO Schema30 - Database columns 'user_settings.last_fm_*' were added successfully.
[2011-09-10 11:29:16,611] INFO Schema30 - Database column 'user_settings.transcode_scheme' not found. Creating it.
[2011-09-10 11:29:16,612] INFO Schema30 - Database column 'user_settings.transcode_scheme' was added successfully.
[2011-09-10 11:29:16,613] INFO Schema31 - Updating database schema to version 7.
[2011-09-10 11:29:16,613] INFO Schema31 - Database column 'music_file_info.enabled' not found. Creating it.
[2011-09-10 11:29:16,614] INFO Schema31 - Database column 'music_file_info.enabled' was added successfully.
[2011-09-10 11:29:16,614] INFO Schema31 - Database column 'transcoding.default_active' not found. Creating it.
[2011-09-10 11:29:16,614] INFO Schema31 - Database column 'transcoding.default_active' was added successfully.
[2011-09-10 11:29:16,615] INFO Schema32 - Updating database schema to version 8.
[2011-09-10 11:29:16,615] INFO Schema32 - Database column 'user_settings.show_now_playing' not found. Creating it.
[2011-09-10 11:29:16,616] INFO Schema32 - Database column 'user_settings.show_now_playing' was added successfully.
[2011-09-10 11:29:16,616] INFO Schema32 - Database column 'user_settings.selected_music_folder_id' not found. Creating it.
[2011-09-10 11:29:16,617] INFO Schema32 - Database column 'user_settings.selected_music_folder_id' was added successfully.
[2011-09-10 11:29:16,617] INFO Schema32 - Database table 'podcast_channel' not found. Creating it.
[2011-09-10 11:29:16,617] INFO Schema32 - Database table 'podcast_channel' was created successfully.
[2011-09-10 11:29:16,618] INFO Schema32 - Database table 'podcast_episode' not found. Creating it.
[2011-09-10 11:29:16,619] INFO Schema32 - Database table 'podcast_episode' was created successfully.
[2011-09-10 11:29:16,619] INFO Schema32 - Role 'podcast' not found in database. Creating it.
[2011-09-10 11:29:16,620] INFO Schema32 - Role 'podcast' was created successfully.
[2011-09-10 11:29:16,620] INFO Schema33 - Updating database schema to version 9.
[2011-09-10 11:29:16,621] INFO Schema33 - Database column 'player.client_side_playlist' not found. Creating it.
[2011-09-10 11:29:16,621] INFO Schema33 - Database column 'player.client_side_playlist' was added successfully.
[2011-09-10 11:29:16,621] INFO Schema34 - Updating database schema to version 10.
[2011-09-10 11:29:16,622] INFO Schema34 - Database column 'user.ldap_authenticated' not found. Creating it.
[2011-09-10 11:29:16,622] INFO Schema34 - Database column 'user.ldap_authenticated' was added successfully.
[2011-09-10 11:29:16,622] INFO Schema34 - Database column 'user_settings.party_mode_enabled' not found. Creating it.
[2011-09-10 11:29:16,623] INFO Schema34 - Database column 'user_settings.party_mode_enabled' was added successfully.
[2011-09-10 11:29:16,623] INFO Schema35 - Updating database schema to version 11.
[2011-09-10 11:29:16,633] INFO Schema35 - Database column 'user_settings.now_playing_allowed' not found. Creating it.
[2011-09-10 11:29:16,633] INFO Schema35 - Database column 'user_settings.now_playing_allowed' was added successfully.
[2011-09-10 11:29:16,634] INFO Schema35 - Database column 'user_settings.web_player_default' not found. Creating it.
[2011-09-10 11:29:16,634] INFO Schema35 - Database column 'user_settings.web_player_default' was added successfully.
[2011-09-10 11:29:16,635] INFO Schema35 - Role 'stream' not found in database. Creating it.
[2011-09-10 11:29:16,635] INFO Schema35 - Role 'stream' was created successfully.
[2011-09-10 11:29:16,635] INFO Schema35 - Database table 'system_avatar' not found. Creating it.
[2011-09-10 11:29:16,636] INFO Schema35 - Database table 'system_avatar' was created successfully.
[2011-09-10 11:29:16,675] INFO Schema35 - Created avatar 'Formal'.
[2011-09-10 11:29:16,677] INFO Schema35 - Created avatar 'Engineer'.
[2011-09-10 11:29:16,678] INFO Schema35 - Created avatar 'Footballer'.
[2011-09-10 11:29:16,679] INFO Schema35 - Created avatar 'Green-Boy'.
[2011-09-10 11:29:16,680] INFO Schema35 - Created avatar 'Linux-Zealot'.
[2011-09-10 11:29:16,682] INFO Schema35 - Created avatar 'Mac-Zealot'.
[2011-09-10 11:29:16,682] INFO Schema35 - Created avatar 'Windows-Zealot'.
[2011-09-10 11:29:16,683] INFO Schema35 - Created avatar 'Army-Officer'.
[2011-09-10 11:29:16,684] INFO Schema35 - Created avatar 'Beatnik'.
[2011-09-10 11:29:16,686] INFO Schema35 - Created avatar 'All-Caps'.
[2011-09-10 11:29:16,687] INFO Schema35 - Created avatar 'Clown'.
[2011-09-10 11:29:16,688] INFO Schema35 - Created avatar 'Commie-Pinko'.
[2011-09-10 11:29:16,689] INFO Schema35 - Created avatar 'Forum-Flirt'.
[2011-09-10 11:29:16,690] INFO Schema35 - Created avatar 'Gamer'.
[2011-09-10 11:29:16,691] INFO Schema35 - Created avatar 'Hopelessly-Addicted'.
[2011-09-10 11:29:16,692] INFO Schema35 - Created avatar 'Jekyll-And-Hyde'.
[2011-09-10 11:29:16,693] INFO Schema35 - Created avatar 'Joker'.
[2011-09-10 11:29:16,694] INFO Schema35 - Created avatar 'Lurker'.
[2011-09-10 11:29:16,695] INFO Schema35 - Created avatar 'Moderator'.
[2011-09-10 11:29:16,697] INFO Schema35 - Created avatar 'Newbie'.
[2011-09-10 11:29:16,698] INFO Schema35 - Created avatar 'No-Dissent'.
[2011-09-10 11:29:16,699] INFO Schema35 - Created avatar 'Performer'.
[2011-09-10 11:29:16,700] INFO Schema35 - Created avatar 'Push-My-Button'.
[2011-09-10 11:29:16,701] INFO Schema35 - Created avatar 'Ray-Of-Sunshine'.
[2011-09-10 11:29:16,702] INFO Schema35 - Created avatar 'Red-Hot-Chili-Peppers-1'.
[2011-09-10 11:29:16,703] INFO Schema35 - Created avatar 'Red-Hot-Chili-Peppers-2'.
[2011-09-10 11:29:16,704] INFO Schema35 - Created avatar 'Red-Hot-Chili-Peppers-3'.
[2011-09-10 11:29:16,705] INFO Schema35 - Created avatar 'Red-Hot-Chili-Peppers-4'.
[2011-09-10 11:29:16,705] INFO Schema35 - Created avatar 'Ringmaster'.
[2011-09-10 11:29:16,716] INFO Schema35 - Created avatar 'Rumor-Junkie'.
[2011-09-10 11:29:16,718] INFO Schema35 - Created avatar 'Sozzled-Surfer'.
[2011-09-10 11:29:16,719] INFO Schema35 - Created avatar 'Statistician'.
[2011-09-10 11:29:16,721] INFO Schema35 - Created avatar 'Tech-Support'.
[2011-09-10 11:29:16,722] INFO Schema35 - Created avatar 'The-Guru'.
[2011-09-10 11:29:16,723] INFO Schema35 - Created avatar 'The-Referee'.
[2011-09-10 11:29:16,724] INFO Schema35 - Created avatar 'Troll'.
[2011-09-10 11:29:16,725] INFO Schema35 - Created avatar 'Uptight'.
[2011-09-10 11:29:16,726] INFO Schema35 - Created avatar 'Fire-Guitar'.
[2011-09-10 11:29:16,727] INFO Schema35 - Created avatar 'Drum'.
[2011-09-10 11:29:16,728] INFO Schema35 - Created avatar 'Headphones'.
[2011-09-10 11:29:16,728] INFO Schema35 - Created avatar 'Mic'.
[2011-09-10 11:29:16,729] INFO Schema35 - Created avatar 'Turntable'.
[2011-09-10 11:29:16,730] INFO Schema35 - Created avatar 'Vinyl'.
[2011-09-10 11:29:16,730] INFO Schema35 - Created avatar 'Cool'.
[2011-09-10 11:29:16,731] INFO Schema35 - Created avatar 'Laugh'.
[2011-09-10 11:29:16,732] INFO Schema35 - Created avatar 'Study'.
[2011-09-10 11:29:16,732] INFO Schema35 - Database table 'custom_avatar' not found. Creating it.
[2011-09-10 11:29:16,733] INFO Schema35 - Database table 'custom_avatar' was created successfully.
[2011-09-10 11:29:16,733] INFO Schema35 - Database column 'user_settings.avatar_scheme' not found. Creating it.
[2011-09-10 11:29:16,733] INFO Schema35 - Database column 'user_settings.avatar_scheme' was added successfully.
[2011-09-10 11:29:16,734] INFO Schema35 - Database column 'user_settings.system_avatar_id' not found. Creating it.
[2011-09-10 11:29:16,734] INFO Schema35 - Database column 'user_settings.system_avatar_id' was added successfully.
[2011-09-10 11:29:16,734] INFO Schema35 - Database column 'player.jukebox' not found. Creating it.
[2011-09-10 11:29:16,735] INFO Schema35 - Database column 'player.jukebox' was added successfully.
[2011-09-10 11:29:16,735] INFO Schema36 - Updating database schema to version 12.
[2011-09-10 11:29:16,735] INFO Schema36 - Database column 'player.technology' not found. Creating it.
[2011-09-10 11:29:16,736] INFO Schema36 - Database column 'player.technology' was added successfully.
[2011-09-10 11:29:16,736] INFO Schema37 - Updating database schema to version 13.
[2011-09-10 11:29:16,736] INFO Schema37 - Role 'settings' not found in database. Creating it.
[2011-09-10 11:29:16,737] INFO Schema37 - Role 'settings' was created successfully.
[2011-09-10 11:29:16,737] INFO Schema37 - Role 'jukebox' not found in database. Creating it.
[2011-09-10 11:29:16,738] INFO Schema37 - Role 'jukebox' was created successfully.
[2011-09-10 11:29:16,739] INFO Schema37 - Database column 'music_folder.changed' not found. Creating it.
[2011-09-10 11:29:16,757] INFO Schema37 - Database column 'music_folder.changed' was added successfully.
[2011-09-10 11:29:16,757] INFO Schema37 - Database column 'internet_radio.changed' not found. Creating it.
[2011-09-10 11:29:16,757] INFO Schema37 - Database column 'internet_radio.changed' was added successfully.
[2011-09-10 11:29:16,758] INFO Schema37 - Database column 'user_settings.changed' not found. Creating it.
[2011-09-10 11:29:16,758] INFO Schema37 - Database column 'user_settings.changed' was added successfully.
[2011-09-10 11:29:16,759] INFO Schema38 - Updating database schema to version 14.
[2011-09-10 11:29:16,759] INFO Schema38 - Database column 'player.client_id' not found. Creating it.
[2011-09-10 11:29:16,759] INFO Schema38 - Database column 'player.client_id' was added successfully.
[2011-09-10 11:29:16,760] INFO Schema38 - Database column 'user_settings.show_chat' not found. Creating it.
[2011-09-10 11:29:16,761] INFO Schema38 - Database column 'user_settings.show_chat' was added successfully.
[2011-09-10 11:29:16,761] INFO Schema40 - Updating database schema to version 15.
[2011-09-10 11:29:16,762] INFO Schema40 - Reset stream byte count statistics.
[2011-09-10 11:29:16,762] INFO Schema43 - Updating database schema to version 16.
[2011-09-10 11:29:16,763] INFO Schema43 - Updating database schema to version 17.
[2011-09-10 11:29:16,770] INFO Schema43 - Created video transcoding configuration.
[2011-09-10 11:29:16,770] INFO Schema43 - Database column 'user.email' not found. Creating it.
[2011-09-10 11:29:16,771] INFO Schema43 - Database column 'user.email' was added successfully.
[2011-09-10 11:29:16,771] INFO Schema45 - Updating database schema to version 18.
[2011-09-10 11:29:16,772] INFO Schema45 - Role 'share' not found in database. Creating it.
[2011-09-10 11:29:16,772] INFO Schema45 - Role 'share' was created successfully.
[2011-09-10 11:29:16,772] INFO Schema45 - Table 'share' not found in database. Creating it.
[2011-09-10 11:29:16,773] INFO Schema45 - Table 'share' was created successfully.
[2011-09-10 11:29:16,773] INFO Schema45 - Table 'share_file' not found in database. Creating it.
[2011-09-10 11:29:16,773] INFO Schema45 - Table 'share_file' was created successfully.
[2011-09-10 11:29:16,773] INFO DaoHelper - Done checking database schema.
[2011-09-10 11:29:17,012] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sun Sep 11 03:00:00 CEST 2011
[2011-09-10 11:29:17,012] INFO SearchService - Search index not found on disk. Creating it.
[2011-09-10 11:29:17,012] INFO SearchService - Starting to create search index.
[2011-09-10 11:29:17,032] INFO SearchService - Updating Lucene search index.
[2011-09-10 11:29:17,264] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Sep 10 11:34:17 CEST 2011
[2011-09-10 11:29:17,318] INFO SearchService - Created search index with 0 entries.
[2011-09-10 11:29:20,224] INFO NetworkService - Deleted port mapping for port 80
[2011-09-10 11:34:17,350] INFO PodcastService - Starting scheduled Podcast refresh.
[2011-09-10 11:34:17,351] INFO PodcastService - Completed scheduled Podcast refresh.
[2011-09-11 03:00:00,250] INFO SearchService - Starting to create search index.
[2011-09-11 03:00:00,312] INFO SearchService - Updating Lucene search index.
[2011-09-11 03:00:01,113] INFO SearchService - Created search index with 0 entries.
magnusoverli
Postby hexapus » Sun Sep 11, 2011 11:54 am
I just did a completely fresh OS reinstall on my server, newesst Ubuntu x64. I forgot to install openjdk-6-jre at first, and it failed there...so I installed that, and subsonic was running like a charm and I was a happy camper. Then I changed some settings, was futzing with some other stuff, and I restarted subsonic again. Now I'm getting the same behavior as before. It just doesn't act like there's anything running or being served on that port. Even if I try to connect with the IP or from localhost, nothing. I'm really puzzled. I have no .lck file there either and there's definitely only one copy of subsonic running. :-/
hexapus
Postby hexapus » Sun Sep 11, 2011 12:06 pm
Meh, I tried changing the user under which it was running in /var/default/subsonic and then followed the instructions for changing ownership of the files/directories as noted. At first blush, it didn't seem to work, but then I tried localhost, and it did...so I tried the remote connection, and it did as well. I guess I'm good...I'm just kinda scared to restart it now :-
hexapus
Postby magnusoverli » Sun Sep 11, 2011 12:45 pm
What user is it set up to run as now?
Hmmm... I don´t have a /var/default folder??? I do however have a /etc/default folder?
magnusoverli
Users browsing this forum: Google [Bot] and 25 guests
