"subsonic.org is registered, but could not connect to it. (C
Postby kc1 » Sun Sep 11, 2011 8:07 pm
I have donated, and had this working before, but for some reasons it's not working now.
"Automatically configure your router..." is ticked
It says "Status: Successfully forwarding port 4040."
My router (Netgear WNDR400) says the UPNP TCP port is open and pointing to the right LAN IP.
canyouseeme.org says "Connection timed out"
I've tried: unticking "Automatically configure your router..." and manually forwarding 4040 to the right LAN sever. No joy.
Connecting on the LAN works fine
Connecting on my 3G phone using the dynamic IP address works fine.
What is going wrong?
kc1
Re: "subsonic.org is registered, but could not connect to it
Postby BinaryBuddha » Mon Sep 19, 2011 10:40 pm
either your network speed is saturated/laggy or your system is could probably be bogged down. I had the same issue once. I moved the install to a different computer at home that wasn't in use and now I can get to it.
I'm assuming you have the DNS setup correctly pointing to your network so you can reach it from outside your network. I run a static IP at home. But if you haven't set it up, you might be able to use dynamic DNS to point to your home network.
BinaryBuddha
Postby BKKKPewsey » Tue Sep 20, 2011 12:54 am
In settings/network does it still say successfully registered web address?
