Subsonic.org subdomain being registered with wrong IP
Postby cdawzrd » Wed Sep 14, 2011 11:11 pm
I'm running Subsonic 4.5 (build 2384) on Linux x86-64. Subsonic works great, but I recently moved and have a different network config. Previously, the Subsonic server had a world-routable IP, and the *.subsonic.org subdomain was correctly registered. Now, the server is behind a router. UPnP configures properly, i.e. I can put in my WAN IP and login to Subsonic (from outside the LAN), but the *.subsonic.org subdomain is pointing to my server's LAN IP instead of the WAN IP! Obviously, this doesn't work too well from anywhere outside the LAN.
Any tips on resolving this?
cdawzrd
Re: Subsonic.org subdomain being registered with wrong IP
Postby nbrody » Fri Sep 16, 2011 4:15 pm
I have the same problem
nbrody
Postby BKKKPewsey » Fri Sep 16, 2011 10:49 pm
Are you saying that if you use yourname.subsonic.org you cannot connect and settings/network is saying successfully registered web address?
