Internet radio does not play/open
Postby kobby » Fri Sep 16, 2011 11:05 am
I have the problem that the feature Internet Radio does not work.
The URL is correct but nothing happens if i click on the play button.
The same is on the demo page of subsonic.org...
I have tried IExplorer and Firefox.
Who can help?
Best regards
Kobby
kobby
Re: Internet radio does not play/open
Postby BKKKPewsey » Fri Sep 16, 2011 11:58 am
Yep the demo site radio doesn't appear to work. However the internet radio does work BUT it is a bit fussy on the types of streams it will handle - asx work fine.
Try http://listen.di.fm/public5/spacemusic.asx
Which works ok on mine (listening to it now :) )
Note: the weird noises that may emanate from your speakers are normal for this station :wink:
Postby kobby » Fri Sep 16, 2011 1:24 pm
Thank you, yes asx works fine :)
Best regards
Kobby
kobby
Users browsing this forum: Google [Bot] and 22 guests
