Streaming problem with external player (vlc,winamp...)
Postby epsi » Sun Sep 18, 2011 10:34 am
I'm trying to stream video with an external player, but i don't manage. I made a lot of search, so i'm sorry if an answer has been already post! :-(
Streaming works with music, but doesn't with video like avi files.
Here is my encoder line for avi files :
ffmpeg -i %s -f mpeg -b 128k -
Is there something else to do ?
epsi
Re: Streaming problem with external player (vlc,winamp...)
Postby BKKKPewsey » Sun Sep 18, 2011 1:53 pm
If you are using an external player try turning off the transcoding options in SS for external player.
VLC will use its own codecs so need to transcode.
I can get external player with playlist to work ok with vlc but never had much luck with the other option. :?
Postby epsi » Sun Sep 18, 2011 3:24 pm
I tried, but it doesn't change anything. But thanks for the ideas. :p
Ciao
epsi
