Several Questions
Several Questions
Postby Robandcathy » Sun Sep 18, 2011 4:28 pm
I have several questions so Im gonna ask all of them in one topic rather then 10. I skimmed through the tut's and faq's for ansswers.
1. Why is folder art popping up for 1 second and disappering using a computer, works fine with android phone ?
2. Where can I edit the users I created I have had 3 people already log on but do not see options to edit, none showing up under users ? EDIT: I figured it out :oops:
3. I added my videos to the collection with all different extensions and I understand that some might not be supported but I know most of mine are, and they are not showing up.
4. Is there a log kept of who was on and when even if Im not signed in ?
5. Can subsonic run under https rather then http ?
6. Can subsonic use a folder structure, eg. first give the option to chose music or videos? then expand from there.
7. I installed using just the 4.4 .war file, where can i get 4.5 .war ? and what is the difference. I installed subsonic using this method viewtopic.php?f=6&t=7566
can I just replace the .war file, with out having to reset everything up?
8. Are there any other useful transcoders besides lame, and ffmpeg.
9. I donated do I need to download anything to get enhansments ? Already added License.
Ok thats it Thank You for your time :lol:
Robandcathy.
Subsonic 4.4
Windows home server 2011.
Using apache 6.?
Transcoders are lame and ffmpeg
Pain is a state of mind
Weak minded people feel pain
Robandcathy
Re: Several Questions
Postby BKKKPewsey » Sun Sep 18, 2011 9:14 pm
  1. You are using IE9 put it into compatibility mode or use a decent browser.
  2. How did they log on unless you set them up as users? - settings/users.
  3. :? Further info reqd?
  4. No :(
  5. Yes
  6. Yes
  7. The large download button you passed on your way here, read the change log, and I don't know as I don't use the WAR files.
  8. Yes - search the forums but you shouldn't need them
  9. No but you do need to enter your licence details into SS.
If you need further info please read This topic first as there is a lot of differences between OS's and how to configure.
