Trouble Streaming to Wildfire
Postby N]b8*5#cm » Tue Sep 20, 2011 1:57 pm
I'm encountering the 'Required parameter is missing' Error when trying to stream music to my HTC Wildfire.
I've looked through the forums for help, can't find anything.
I've changed the server to a user-defined server on the phone and copy/pasted the server address, username and password.
I've even tried changing the password incase my original one was too complex.
When I press 'test connection', it attempts to contact the server before giving me that Error message.
What could I be doing wrong?
Port-forwarding IS enabled, the browser-based player tells me so, and i can get music to play in that. But I can't get it to stream to the Wildfire
I've also tried trading out the SERVER ADDRESS with my own full IP address and port and get:
A Network Error occurred
After 4 attempts, it says
Error: Connection Failure. A network error occurred. Please check the server address or try again later.
N]b8*5#cm
