Android Stream/Download Stops Working
Postby jjewett » Tue Sep 20, 2011 9:31 pm
I'm running a Droid X. The client connects with my server just fine but it would not start the stream/download process... it just seemed to hang. Rebooting worked for a while (noted in other posts) but the problem would return.
Turns out to be an issue with the SD card. Unmount/mount the card and, like magic, Subsonic works!
So I'm off to Google land to see if others are having issues with SD cards on the X or if I just need to get a new card.
Jeff
jjewett
Re: Android Stream/Download Stops Working
Postby pcs800 » Wed Sep 21, 2011 12:50 am
I have a droid x, no problems here.
pcs800
