Enforcing upstream bit rates
Postby GHOSTRIDER » Mon Jun 18, 2007 4:26 pm
Sindre,
First of all congrats on your marrage and
my regards to your bride,
I wish you both the very best.
I'm posting today to see if you can advise
on a way to enforce player bit rates,
I'll give an example so you can understand
better how I mean.
I create a user login, assign it a set upload
bit rate and everything is cool, then I look at
the graph when that user is on and it's all over the map
(as far as upload bit rate) sometimes in excess of a meg.
is there a way to set a default upload bit rate for all users
logins in the Subsonic files themselves somewhere?
Thanks in advance, I'll check back soon..
G.
GHOSTRIDER
Postby sindre_mehus » Thu Jun 21, 2007 12:43 pm
Hi and thanks!
The per-user bitrate is only for playback (streaming). The upload/download limit (in Settings > General) can be used to restrict how much bandwidth to use for upload/download.
Note that these values are global. For instance: If you specify 1000 Kbps upload limit, and there are 5 parallel uploads, each upload will be allowed to use 200 Kbps.
Hope this was clarifying :-)
