[Solved] Issue by upgrading 4.4 to 4.5 in Ubuntu
Postby grimy55 » Tue Sep 27, 2011 9:10 pm
I've just tried to upgrade my 4.4 version of subsonic to 4.5. When I dpkg the .deb, I have this error message :
~$ sudo dpkg -i subsonic-4.5.deb
(Reading database ... 78170 files and directories currently installed.)
Preparing to replace subsonic 4.4 (using subsonic-4.5.deb) ...
Unpacking replacement subsonic ...
Setting up subsonic (4.5) ...
Removing any system startup links for /etc/init.d/subsonic ...
   /etc/rc0.d/K99subsonic
   /etc/rc1.d/K99subsonic
   /etc/rc2.d/S99subsonic
   /etc/rc3.d/S99subsonic
   /etc/rc4.d/S99subsonic
   /etc/rc5.d/S99subsonic
   /etc/rc6.d/K99subsonic
Starting subsonic (4.5) ...
Adding system startup for /etc/init.d/subsonic ...
   /etc/rc0.d/K99subsonic -> ../init.d/subsonic
   /etc/rc1.d/K99subsonic -> ../init.d/subsonic
   /etc/rc6.d/K99subsonic -> ../init.d/subsonic
   /etc/rc2.d/S99subsonic -> ../init.d/subsonic
   /etc/rc3.d/S99subsonic -> ../init.d/subsonic
   /etc/rc4.d/S99subsonic -> ../init.d/subsonic
   /etc/rc5.d/S99subsonic -> ../init.d/subsonic
Started Subsonic [PID 1435, /var/subsonic/subsonic_sh.log]
Processing triggers for ureadahead ...
Then, I'm not able to access the web interface anymore. Here are my logs:
~$ cat subsonic.log
[2011-09-27 22:51:18,210] INFO DaoHelper - Checking database schema.
[2011-09-27 22:51:19,332] INFO DaoHelper - Done checking database schema.
[2011-09-27 22:51:19,886] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Wed Sep 28 03:00:00 CEST 2011
[2011-09-27 22:51:20,256] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Sep 27 22:56:20 CEST 2011
[2011-09-27 22:51:23,588] WARN NetworkService - Failed to delete port mapping.
net.sbbi.upnp.messages.UPNPResponseException: Detailed error code :899, Detailed error description :Content is not allowed in prolog.
        at net.sbbi.upnp.messages.ActionMessage.service(ActionMessage.java:179)
        at net.sbbi.upnp.impls.InternetGatewayDevice.deletePortMapping(InternetGatewayDevice.java:417)
        at net.sourceforge.subsonic.domain.SBBIRouter.deletePortMapping(SBBIRouter.java:61)
        at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:167)
        at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
        at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
        at java.lang.Thread.run(Thread.java:679)
[2011-09-27 22:56:20,251] INFO PodcastService - Starting scheduled Podcast refresh.
[2011-09-27 22:56:20,256] INFO PodcastService - Completed scheduled Podcast refresh.
Does someone have an idea ?
Thanks !
grimy55
Re: Issue by upgrading 4.4 to 4.5
Postby BKKKPewsey » Tue Sep 27, 2011 10:07 pm
If you told us what you are installing it on, in English please, someone may be able to help :?
Postby grimy55 » Tue Sep 27, 2011 10:27 pm
The beginning of the first code shows "~$ sudo dpkg -i subsonic-4.5.deb". So that I am simply trying to upgrade my old version by the new one using the common way.
The dpkg is doing well till the end where the last line could be translated as:
Processing triggers for ureadahead …
If you need the translation of another part of the error message, I'll do it. Sorry for the inconvenience.
UPDATE: the text shown on the first post is know entirely translated in English.
grimy55
Postby Aethies » Wed Sep 28, 2011 12:51 pm
Are there any messages in /var/messages? Also, can you check to see if subsonic is actually running?
$ ps -ef |grep subsonic
If not, try starting the service via
$ sudo /etc/init.d/subsonic start
and then do the ps -ef | grep subsonic
If it is running, check the logs again to see what it is doing.
And for those who don't know this is in english, he is talking about Ubuntu.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby BKKKPewsey » Wed Sep 28, 2011 1:27 pm
Thank you Aethies :D
Postby grimy55 » Wed Sep 28, 2011 1:46 pm
Yeah, it seems that we speak many languages here. Thank you for the clarification.
Subsonic was already running, and there is no messages in /var/messages
Here is again the subsonic.log:
~$ cat /var/subsonic/subsonic.log
[2011-09-28 03:39:02,766] INFO DaoHelper - Checking database schema.
[2011-09-28 03:39:05,309] INFO DaoHelper - Done checking database schema.
[2011-09-28 03:39:06,198] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Thu Sep 29 03:00:00 CEST 2011
[2011-09-28 03:39:06,526] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Sep 28 03:44:06 CEST 2011
[2011-09-28 03:39:09,942] WARN NetworkService - Failed to delete port mapping.
[2011-09-28 03:44:06,536] INFO PodcastService - Starting scheduled Podcast refresh.
[2011-09-28 03:44:06,692] INFO PodcastService - Completed scheduled Podcast refresh.
[2011-09-28 03:45:26,781] WARN PodcastService - Failed to get/parse RSS file for Podcast channel http://radiofrance-podcast.net/podcast09/rss_11549.xml
java.net.UnknownHostException: radiofrance-podcast.net
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:175)
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
        at java.net.Socket.connect(Socket.java:546)
        at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:123)
        at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:123)
        at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:147)
        at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:108)
        at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:415)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:576)
        at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:554)
        at net.sourceforge.subsonic.service.PodcastService.doRefreshChannel(PodcastService.java:251)
        at net.sourceforge.subsonic.service.PodcastService.access$100(PodcastService.java:67)
        at net.sourceforge.subsonic.service.PodcastService$3.run(PodcastService.java:230)
        at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
        at java.util.concurrent.FutureTask.run(FutureTask.java:166)
[2011-09-28 03:45:26,785] WARN PodcastService - Failed to get/parse RSS file for Podcast channel http://radiofrance-podcast.net/podcast09/rss_11739.xml
[2011-09-28 03:45:26,787] WARN PodcastService - Failed to get/parse RSS file for Podcast channel http://radiofrance-podcast.net/podcast09/rss_10385.xml
and here is the subsonic_sh.log:
~$ cat /var/subsonic/subsonic_sh.log
177 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@50337d0f: display name [org.springframework.context.support.ClassPathXmlApplicationContext@50337d0f]; startup date [Wed Sep 28 03:38:55 CEST 2011]; root of context hierarchy
380 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
[GC 5952K->324K(21376K), 0.0061100 secs]
1069 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@50337d0f]: org.springframework.beans.factory.support.DefaultListableBeanFactory@781f6226
1120 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@781f6226: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
1182 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
[GC 6276K->483K(21376K), 0.0058220 secs]
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/2384
1343 [main] INFO org.mortbay.log - jetty-6.1.x
[GC 6427K->893K(21376K), 0.0064000 secs]
[GC 6845K->844K(21376K), 0.0044300 secs]
[GC 6796K->1087K(21376K), 0.0023010 secs]
5453 [main] INFO / - Initializing Spring root WebApplicationContext
5453 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
5508 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@5d7b6643: display name [Root WebApplicationContext]; startup date [Wed Sep 28 03:39:01 CEST 2011]; root of context hierarchy
5563 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
5798 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
[GC 7039K->1305K(21376K), 0.0041830 secs]
5977 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
6073 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@5d7b6643]: org.springframework.beans.factory.support.DefaultListableBeanFactory@538d7ace
6535 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@538d7ace: defining beans [playerDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,musicFileService,securityService,settingsService,searchService,luceneSearchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheManager,userCache,musicFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of factory hierarchy
[GC 7257K->1156K(21376K), 0.0035920 secs]
6714 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
[GC 7098K->2994K(21376K), 0.0088700 secs]
[GC 8939K->4128K(21376K), 0.0048390 secs]
[GC 10080K->4171K(21376K), 0.0025970 secs]
[GC 10123K->4171K(21376K), 0.0009380 secs]
[GC 10120K->4154K(21376K), 0.0010430 secs]
[Full GC 4278K->4111K(21376K), 0.0583800 secs]
9726 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
28 sept. 2011 03:39:05 net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
28 sept. 2011 03:39:05 net.sf.ehcache.Cache initialise
ATTENTION: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
[GC 10127K->4652K(21440K), 0.0041410 secs]
ATTENTION: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
[GC 10668K->5059K(21440K), 0.0085300 secs]
[GC 11075K->6067K(21440K), 0.0108230 secs]
11533 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
11595 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
11595 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
11595 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
[GC 12083K->6813K(21440K), 0.0087200 secs]
11769 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 6316 ms
12015 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
12015 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
12016 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1ca37c6a: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Wed Sep 28 03:39:07 CEST 2011]; parent: org.springframework.web.context.support.XmlWebApplicationContext@5d7b6643
12017 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
[GC 12829K->7371K(21440K), 0.0099100 secs]
12404 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1ca37c6a]: org.springframework.beans.factory.support.DefaultListableBeanFactory@6a25b72a
12671 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@6a25b72a: defining beans [leftController,rightController,statusController,mainController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlaylistController,loadPlaylistController,savePlaylistController,changeCoverArtController,nowPlayingController,searchController,settingsController,playerSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,searchSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playlistController,xspfPlaylistController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,videoPlayerController,externalPlayerController,downloadController,donateController,multiController,wapController,restController,dbController,savePlaylistValidator,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@538d7ace
[GC 13387K->7535K(21440K), 0.0048270 secs]
[GC 13551K->8008K(21440K), 0.0059490 secs]
[GC 14024K->8400K(21440K), 0.0055020 secs]
[GC 14416K->9042K(21440K), 0.0066020 secs]
14333 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 2318 ms
14412 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
14536 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
[Full GC 14056K->9375K(21440K), 0.3646430 secs]
15001 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
15151 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
[Full GC 12350K->9448K(22732K), 0.1450330 secs]
[Full GC 10749K->8135K(22732K), 0.1594550 secs]
[Full GC 9436K->8135K(22732K), 0.1317380 secs]
[Full GC 9436K->8135K(22732K), 0.1367990 secs]
[Full GC 9436K->8135K(22732K), 0.1396340 secs]
[Full GC 9436K->8135K(22732K), 0.1354440 secs]
[Full GC 9436K->8135K(22732K), 0.1490800 secs]
[Full GC 9436K->8135K(22732K), 0.1335550 secs]
[Full GC 9436K->8135K(22732K), 0.1403240 secs]
[Full GC 9436K->8135K(22732K), 0.1329150 secs]
[Full GC 9436K->8135K(22732K), 0.1287820 secs]
[Full GC 9436K->8135K(22732K), 0.1370290 secs]
grimy55
Postby Aethies » Wed Sep 28, 2011 4:38 pm
Can you post the output of your netstat?
$ netstat -l
That should help us determine if it is actually listening on the right ports or if it is listening at all.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby grimy55 » Wed Sep 28, 2011 6:00 pm
Here is:
$ netstat -l
Connexions Internet actives (seulement serveurs) ##Active internet connexions (only server)##
Proto Recv-Q Send-Q Local Address          Distant Address        State
tcp        0      0 *:sunrpc                *:*                     LISTEN
tcp        0      0 *:www                   *:*                     LISTEN
tcp        0      0 *:275                   *:*                     LISTEN
tcp        0      0 *:ssh                   *:*                     LISTEN
tcp        0      0 localhost:6010          *:*                     LISTEN
tcp        0      0 *:microsoft-ds          *:*                     LISTEN
tcp        0      0 localhost:mysql         *:*                     LISTEN
tcp        0      0 *:netbios-ssn           *:*                     LISTEN
tcp6       0      0 [::]:275                [::]:*                  LISTEN
tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
tcp6       0      0 localhost:6010          [::]:*                  LISTEN
tcp6       0      0 [::]:54527              [::]:*                  LISTEN
tcp6       0      0 [::]:9412               [::]:*                  LISTEN
tcp6       0      0 [::]:4040               [::]:*                  LISTEN
udp        0      0 *:sunrpc                *:*
udp        0      0 192.168.0.25:netbios-ns *:*
udp        0      0 192.168.0.21:netbios-ns *:*
udp        0      0 *:netbios-ns            *:*
udp        0      0 192.168.0.2:netbios-dgm *:*
udp        0      0 *:netbios-dgm           *:*
Sockets du domaine UNIX actives (seulement serveurs) ##Active sockets of the UNIX domain (only server)##
Proto RefCnt Flags       Type       State         I-Node   Chemin
unix  2      [ ACC ]     STREAM     LISTENING     7811     /tmp/.winbindd/pipe
unix  2      [ ACC ]     STREAM     LISTENING     6670     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     6046     @/com/ubuntu/upstart
unix  2      [ ACC ]     STREAM     LISTENING     7812     /var/run/samba/winbindd_privileged/pipe
unix  2      [ ACC ]     STREAM     LISTENING     7562     /var/run/mysqld/mysqld.sock
grimy55
Postby Aethies » Wed Sep 28, 2011 8:17 pm
grimy55 wrote:Here is:
$ netstat -l
Is your subsonic running on port 6010? Cause if it is.. then you should be able to type localhost:6010, instead of the default, 8081 or whatever..
if that is not your subsonic port, then for some reason, it is not listening. If that is the case, there should be a thread on troubleshooting the port that subsonic is on.
Hope this helps.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby grimy55 » Wed Sep 28, 2011 10:04 pm
Actually, why the port 6010 is opened is another issue that I need to fix !
Concerning my issue with subsonic, it is solved, thanks to you. I saw that subsonic is actually listening the port 4040, as usual, but I used another port before the upgrade. I've checked that my configuration file /etc/default/subsonic is the one by default. The upgrade certainly reset it. I've just had to change the port once more and it works now.
Thanks for your help !
grimy55
Users browsing this forum: Google [Bot] and 26 guests
