I'm sure someone has brought this up before but I couldn't locate any info:
I have 2 media Folders:
1. Main Library
2. Private Library
Is there a way to hide the Private Library from certain users and give access to it to others?
thx
but some abuse the privilege!BKKKPewsey wrote:If you look at the feature request section I think you will find that something similar to this has been asked for before
so I would suggest you place your votes there. The more votes the more likely it will get implemented (We hope)
With he relatively new advent of video to SS I agree that the issue of limiting certain users to certain folders, just on the bandwidth issue alone, is important.
but some abuse the privilege!Users browsing this forum: No registered users and 65 guests
