Subsonic will not connect over 3g
Postby painscough » Mon Oct 03, 2011 2:53 am
I just recently started having problems with my subsonic connecting over 3g on my android phone. I receive "A network error occurred. Retrying" error message.
I have verified that my port is forwarded correctly. I can pull up the UI through a browser off of my home network that always works fine. If I am on my works wifi network I can connect to my subsonic through my android device but when I am on my 3g network I get the network error occurred message. This has worked on my android device previously. I have tried to uninstall and reinstall the app and it worked once and then started giving the error message again.
I have searched the forums a few times but cannot find an answer. Anyone have any ideas to try I can't think of anything else really.
Thanks in advance.
painscough
Re: Subsonic will not connect over 3g
Postby rakathi » Tue Dec 27, 2011 6:24 am
I am having the exact same problem,
Works over Wifi, internal and external, but does not work over 3g
Have you discovered a solution to this issue>?
I haven't been able to find a solution,
Cheers in advance.
rakathi
