users settings page broken subsonic 4.5
Postby patsee14 » Mon Oct 03, 2011 12:26 pm
I switched from using the Subsonic ubuntu installer (.deb) to Tomcat 7 and subsonic war 4.5.
Every time I want to change the admin password, after clicking the "users" link on the settings page I get the error quoted below... Playing music works fine.
my system:
Ubuntu natty 64 Bit (kernel: 2.6.38-11-server)
Tomcat 7 and sun java 6 (update 27)
Error
Exception org.apache.jasper.JasperException
Message /WEB-INF/jsp/userSettings.jsp (line: 124, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
Java version Sun Microsystems Inc. 1.6.0_27
Operating system Linux 2.6.38-11-server
Server Apache Tomcat/7.0.22
Memory Used 60 of 155 MB
Stack trace org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp (line: 124, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42)
at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408)
at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:199)
at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1218)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:870)
at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539)
at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376)
at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:889)
at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2434)
at org.apache.jasper.compiler.Node$Root.accept(Node.java:475)
at org.apache.jasper.compiler.Validator.validateExDirectives(Validator.java:1790)
at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:217)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:373)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:644)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:358)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:389)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:333)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:684)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:471)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:402)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:329)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:964)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:304)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
When clicking the "Personal" settings link I get the following messeage:
Message /WEB-INF/jsp/personalSettings.jsp (line: 43, column: 20) "${default}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${default}]
thanks in advance,
patsee14
patsee14
Re: users settings page broken subsonic 4.5
Postby BKKKPewsey » Tue Oct 04, 2011 12:53 am
patsee14 wrote:Hello,
my system:
From the installation instructions
Postby patsee14 » Tue Oct 04, 2011 4:03 pm
oops, my fault. I will try again with tomcat 6 and see if these error messages still exist ...
patsee14
Postby patsee14 » Tue Oct 04, 2011 7:27 pm
everything seems to be working fine now. I'm using tomcat 6 from the Ubuntu repo. Thanks BKKKPewsey for your hint!
patsee14
