podcasts in android app
Postby kpholmes » Mon Oct 03, 2011 12:40 pm
i am having difficulty finding the podcasts that are downloaded to my server via the standard android app. can anyone point me in the right direction? thanks
kpholmes
Re: podcasts in android app
Postby kpholmes » Thu Oct 13, 2011 12:43 pm
really? no one knows?
kpholmes
Postby martyscholes » Fri Oct 14, 2011 1:01 am
I don't understand. I don't think you can download podcasts to Subsonic "via the standard android app." I have Subsonic download my podcasts for me then play them on the Android phone.
martyscholes
Postby alphawave7 » Fri Oct 14, 2011 3:45 am
martyscholes wrote:I don't understand. I don't think you can download podcasts to Subsonic "via the standard android app." I have Subsonic download my podcasts for me then play them on the Android phone.
Same here: server dumps podcasts to /music/Podcasts folder (which is listed among Artists) and they are listed in sequence there. I simply nav to Artist-Podcasts to see and play them.
Postby Minime » Fri Oct 14, 2011 12:44 pm
One thing you can do is to create a shortcut for your Podcasts folder so it appears at the top of the list and you don't have to scroll down a lot to locate it. Go to : Settings - General and then in the "Shortcuts" field add: Podcasts "Podcasts".What is in between the quotes is the name of your Podcasts folder.This also creates a shortcut on the left side menu when using a browser and also makes it appear at the top of the list when using Android.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Postby martyscholes » Fri Oct 14, 2011 12:49 pm
Or just make a Podcast folder. I have a folder each for Music, Video, Podcasts and Old Time Radio shows.
martyscholes
Users browsing this forum: Google [Bot] and 26 guests
