I am using windows XP. Despite an hour searching, I cannot find how to specify the playlist folder!
thanks for any help!
JL
but some abuse the privilege!johnlattanzio wrote:The plot thickens...
1) If I start from the tray it goes to localhost and the settings tab allows me to alter the directory of the playlist, as per the instruction above.
2) if I start from IPaddress:4040 I access my music server but then do not have the same large number of settings available.
Clearly I have not understood everything here.
I do not need the files on localhost now that everything is loaded onto my music server - how do I specify the IP address of the
server in the Settings > Media Folder section (I have disabled the files on localhost)
but some abuse the privilege!Users browsing this forum: No registered users and 17 guests
