Don't see "settings" tab on android app - Galaxy S2
Postby toecephus » Sat Oct 08, 2011 5:18 am
I just got my first Droid today, Galaxy S2 on ATT
I setup Subsonic on my PC everything is working fine there I can stream from the browser.
I installed Subsonic Android app on the phone. I can play music fine on the demo server.
However, when I click on the "Select a server" "Unused 1" there is no option for "Settings" tab.
If I click on the media library tab I get "Username may not be null"
I can't figure out what I am doing wrong, thanks for the help. If I can just get to the settings tab I can input the server settings, but just can't find it!
See screen caps.
Thanks for the help!
Andy
toecephus
Re: Don't see "settings" tab on android app - Galaxy S2
Postby jsr » Tue Oct 11, 2011 2:09 pm
You need to use the Menu button (bottom, furthest left, under the screen). This brings up additional options, including settings.
-Jeff
jsr
Postby acetulloch » Wed Aug 15, 2012 8:33 pm
I have just purchased a samsung galaxy tab 7.0 and downloaded the Subsonic app from Samsung Apps however I am unable to find the Settings option on the app. There is no option for settings when clicking on the Home (bottom left icon) or any of the others. Can anyone help?
acetulloch
Postby acetulloch » Wed Aug 15, 2012 8:37 pm
This is all I have....please help!
acetulloch
Postby Alf » Sat Sep 22, 2012 6:17 pm
I have the same problem. There is just nothing to click called "settings".
Phone is an HTC desire C - Android 4.0. It doesn't have a menu button, so I cant look for settings there.
I think there should be an action bar or something, but there isn't.
Alf
Postby MadEvil » Mon Sep 24, 2012 10:53 am
Alf wrote:I have the same problem. There is just nothing to click called "settings".
... use this button for settings :wink:
best regards
Madsonic Developer
MadEvil
