trouble with 4.5 (build 2385)
Postby Avarell_Dalton » Sat Oct 08, 2011 3:00 pm
Hi.
Since last upgrade I have had a couple of errors (try seeking on that).
First a Error pop up warning in the web ui which is solved by closing it and keep on listening.
Secondly. Web ui, and the player refuses to play files. I try another file, playes fine, goes back to error file and it plays fine. What happens is that I choose a file to play, the file ends up in the bottom section but will not play, no error messages or anything.
Third. When I was using a specific acoount in web ui browser reported "guest" was plaing what i played. So i deleted guest account and tried again. Then I couldn't play anything. Deleted my account and reopened it. Same error. So I ended up creating a completly new account and now everything work as supposed.
So what have I done to solve this? Absolutely nothing. If anyone is going to suggest a uninstall/install, is there a way to backup user accounts and whatnot?
BTW, Sindre, you are my hero. I really love your work. I even link to subsonic in my sig in a android forum. Uses web ui and android app for hours every day. I thank you!
Avarell_Dalton
Re: trouble with 4.5 (build 2385)
Postby Avarell_Dalton » Sun Oct 09, 2011 8:20 am
There are a few things more I'd like to add
Sometimes when playing mp3's they just stops in the middle of the song and sometimes continues playing next song or comes to a total halt.
No error info given at all.
Avarell_Dalton
Postby Avarell_Dalton » Fri Oct 21, 2011 3:23 pm
Ok, this was apparently a hard nut to crack. Maybe I'm the first to experience this. Well good for you all!
Avarell_Dalton
