Windows can not find subsonic
Postby Guzzisti » Sun Oct 09, 2011 11:17 pm
I've had no problems with subsonic until about a month ago when it stopped working. When I try to launch subsonic now it says "Missing Shortcut" and can not find subsonic.url. I've uninstalled and reinstalled a few times, uninstalled google desktop, etc but no luck. I also checked the router and it is still configured properly.
Guzzisti
Re: Windows can not find subsonic
Postby BKKKPewsey » Sun Oct 09, 2011 11:25 pm
Postby Guzzisti » Mon Oct 10, 2011 11:45 am
BKKKPewsey wrote:Welcome
May I suggest a read of http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506
About 90% is unavailable since Subsonic won't open.
Problem Description: When I try to launch subsonic now it says "Missing Shortcut" and can not find subsonic.url.
Troubleshooting Steps: I've uninstalled and reinstalled a few times, uninstalled google desktop, etc but no luck. I also checked the router and it is still configured properly.
Playback Application and version: (The end application that you are using to stream from Subsonic)
Subsonic Version: 4.5
Server Version: Unavailable
Hardware Platform: Windows 7
Java Memory Limit: Unavailable
Problem Filename: subsonic.url
Output from ffmpeg -i: The system cannot find the specified file.
Last ten log file lines: Unavailable
Guzzisti
Postby BKKKPewsey » Mon Oct 10, 2011 12:26 pm
But one of the most important pieces of info is
Therefore you will have a control panel (Subsonic user agent) in the notification area.
Is this red or green (stopped or running)? Does it show any error messages?
What happens when you click on the link?
Postby Guzzisti » Mon Oct 10, 2011 7:02 pm
Nope. When I attempt to start subsonic a cmd screen flashes for a second but nothing comes of it.
Opening the tray icon does nothing.
Clicking Open Subsonic gives me the following:
Guzzisti
Postby BKKKPewsey » Mon Oct 10, 2011 7:56 pm
Is SS in your list of installed Programs?
So you do have a tray icon - I shall ask again - is it red or green?
If you right click it and select open what do you see?
It should tell you if SS is running and memory used or give an error
Postby Guzzisti » Tue Oct 11, 2011 10:53 am
Sorry I wasn't clear. I am clicking on Subsonic Tray Icon in the Subsonic folder in the start menu. There is no subsonic tray icon at the bottom of the screen. I know what you are referring to and it used to be there when subsonic was functioning.
Guzzisti
Postby BKKKPewsey » Tue Oct 11, 2011 9:17 pm
Have you checked that Windows has SS in its list of installed programs?
Did you install SS in its default locations? in which case you will have a subsonic folder in Program Files with subsonic-agent.exe (control panel) and subsonic-service.exe.
You should also have a subsonic folder in your c:drive - have you?
Postby Guzzisti » Tue Oct 11, 2011 11:22 pm
The default location is the program files (x86) folder. I've tried in both that folder and the Program folder. Both the subsonic-agent.exe (control panel) and subsonic-service.exe are in the folders. I also have the C:subsonic folder with the transcode folder.
Guzzisti
Postby BKKKPewsey » Wed Oct 12, 2011 12:07 am
Guzzisti wrote: I also have the C:subsonic folder with the transcode folder.
The C:\Subsonic folder should also contain folders db, jetty, & lucene at least - does it?
If not it is not installing correctly.
Remove SS via Add/Remove programs in control panel and then delete the C:\Subsonic folder then re-install.
You will lose your settings though so be warned.
Postby Guzzisti » Wed Oct 12, 2011 2:11 am
Nope. I've uninstalled, deleted the folders, and even went so far as to delete the download and re-download. For some reason the remaining files in the c:subsonic folder are not present (or installing I guess).
Guzzisti
Postby BKKKPewsey » Wed Oct 12, 2011 2:39 am
Excuse me for stating the obvious but you are using the Windows installer?
Assuming you are, try installing as an administrator, just right click the "subsonic-4.5-setup.exe" file and select run as administrator.
If that doesn't work I think I have run out of ideas :?
Postby Guzzisti » Wed Oct 12, 2011 11:15 pm
Yup. Windows installer, running as administrator. Thanks though. Not sure why it suddenly stopped. Had just started to use SubsonicTV
Guzzisti
Postby BKKKPewsey » Thu Oct 13, 2011 12:10 am
Notice I did say INSTALL as administrator
Postby Guzzisti » Thu Oct 13, 2011 9:33 pm
Yeah, installing as administer. I installed in xpmode and attempted to copy and paste the missing folder with no luck.
Guzzisti
Users browsing this forum: No registered users and 59 guests
