Cannot Access Server Over Internet
Postby noipod » Mon Oct 10, 2011 7:07 pm
Hi All,
Since yesterday, I am unable to connect to my server over the internet. I'm unsure if this is a problem on my end or not?
There was another help post "Error when going to http://localhost:4040" describing similar issues.
My settings in Subsonic show that ports have been forwarded.
However settings show "xxxxxxx.subsonic.org returned HTTP error code 404 Not Found".
Is there a current problem on the SS end or can I remedy this on my side?
Thanks in advance for any input!
noipod
Re: Cannot Access Server Over Internet
Postby BKKKPewsey » Mon Oct 10, 2011 8:15 pm
If you use yourname.subsonic.org in a browser it will try to access [your server IP:port no] is that your IP?
Check with http://canyouseeme.org from your SS server to check your port is open (which will also give you your ext IP)
