Subsomic Server glitching, need help fixing!
Postby jayw654 » Sat Oct 15, 2011 6:29 am
My server for some reason is glitching. Maybe someone will know how to correct the situation. Here are the issues as follows:
1. When changing theme the log in screen will change but the interface of the main page will not.
2. I'm getting sluggish connections when trying to connect, and no it has nothing to do with my network. Anyway for some reason subsonic refuses or slowly connects 60 percent of the time.
3. mp4 streaming fails to work correctly. Files which streamed fine before will no longer stream in mp4. However, flv files seem to be fine. Mov format files are having the same issue of no longer streaming.
4. Requesting lyrics no longer works as it attempts but give a "No Lyrics Found" error.
So how is everything else working?
1. Audio streaming works fine
2. FLV streaming seems okay
3. Everything else seems to be fine also
I know software sometimes glitches and does weird things. I'm hoping someone has ran into this situation before or at least has some tips for fixing the situation, Thanks!
jayw654
Re: Subsomic Server glitching, need help fixing!
Postby jayw654 » Sat Oct 15, 2011 7:44 am
Here's some additional information which may be needed:
Version
4.5 (build 2385) – August 11, 2011
Server
jetty-6.1.x, java 1.6.0_27, Windows 7 (55.4 MB / 91.4 MB)
jayw654
Postby jayw654 » Sat Oct 15, 2011 8:25 am
Message PreparedStatementCallback; SQL [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?]
Java version Sun Microsystems Inc. 1.6.0_27
Server jetty-6.1.x
Memory Used 39 of 68 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?] at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:106) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:670) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:678) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:710) at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:58) at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:62) at net.sourceforge.subsonic.dao.MusicFileInfoDao.getMusicFileInfoForPath(MusicFileInfoDao.java:51) at net.sourceforge.subsonic.service.MusicInfoService.getMusicFileInfoForPath(MusicInfoService.java:45) at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:105) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139) at org.mortbay.jetty.Server.handle(Server.java:313) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381) at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227) at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442) Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, comment, play_count, last_played, enabled from music_file_info where path=?] at org.hsqldb.jdbc.Util.throwError(Unknown Source) at org.hsqldb.jdbc.jdbcPreparedStatement.executeQuery(Unknown Source) at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:648) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591) ... 63 more
jayw654
Postby jayw654 » Sat Oct 15, 2011 10:07 am
I fixed the problem I killed the c:\subsonic folder and store back the database file. nexted loaded subsonic to create the folders then closed it and put the database file in the set of new folders that were created when subsonic was reopened. Lastly I use the instal file to write any missing files that weren't repopulated by opening the program. All is well now except on thing, Lyrics are not working
jayw654
Re: lyrics not working in v4.5
Postby BKKKPewsey » Sat Oct 15, 2011 12:44 pm
Its most probably not working because chartlyrics.com is not working
which appears to be a regular occurrence :(
Postby jayw654 » Sun Oct 16, 2011 9:14 am
Well if its been a regular occurance why doesn't the writer use a different database?
jayw654
Postby Schokobecher » Tue Oct 25, 2011 8:08 pm
I'm offering a 25$ bounty if someone creates a working mod that utilizes another (or better yet multiple) lyric engine(s).
Or maybe even the option to add lyrics manually.
Payment via Paypal or bank transfer.
Schokobecher
Postby BKKKPewsey » Tue Oct 25, 2011 9:07 pm
Chartlyrics website is still down (over 2 weeks now) so the api is now only really suitable for instrumental tracks :evil:
I think that SS should use embedded lyrics which would then allow all users their lyric engine of choice.
Postby Schokobecher » Tue Oct 25, 2011 9:10 pm
exactly.
Gonna post this in the Feature Request forum, maybe more people are willing to offer a bounty to the coder making this possible :D
Schokobecher
Postby pemholder » Wed Oct 26, 2011 6:06 pm
BKKKPewsey wrote:Chartlyrics website is still down (over 2 weeks now) so the api is now only really suitable for instrumental tracks :evil:
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=2404&p=7960&hilit=lyrics#p7960
pemholder
Users browsing this forum: Google [Bot] and 23 guests
