Shoutcast Internet Radio
Postby monkey » Sun Oct 16, 2011 4:10 pm
Trying to get a shoutcast stream added to subsonic, but it's having none of it.
Is Subsonic capable of handling shoutcast streams?
Even downloaded the stations pls file which gets recognised as a valid playlist but refuses to play.... http://eastmanchesterradio.com/emrlisten.pls
Many thanks
Iain
monkey
Re: Shoutcast Internet Radio
Postby Castius » Sun Oct 16, 2011 6:15 pm
Castius
Postby monkey » Sun Oct 16, 2011 6:49 pm
Castius wrote:It looks like the wrong ink
Try this one.
http://servers.internet-radio.org.uk/to ... pls&t=.pls
I pulled it from here.
http://www.internet-radio.org.uk/search ... manchester
Hi Castius, thanks for the reply,
The stream is actually hosted on my VPS so I'm confident the link is correct,
The link I originally posted is actually an AAC stream, so I thought that may be the cause, but this is not the case because the MP3 stream also exhibits the same problem http://eastmanchesterradio.com/listen.pls
Both files play just fine in any desktop media player, and the MP3 stream works on the site's own flash player.
monkey
Postby Castius » Mon Oct 17, 2011 1:57 am
hmm, both links work now. I don't know whats wrong on your end.
I use xmplay media player.
http://www.un4seen.com/
Castius
Postby monkey » Mon Oct 17, 2011 5:28 pm
I'm looking for it to play in the built in player. JWPlayer does work with Shoutcast streams as I've had it hosted before
Won't use XMPlay as it's a Windows app, and we run mostly Linux here (although I've tested the stream on Ubuntu, Mac OSX and Windows all exhibit the same problem.)
It isn't going to put me off Subsonic, as there are plenty of other ways for me to listen to the radio stream, but it would be something nice to get working.
I'll plod on trying various things if there are no answers forthcoming.
monkey
Postby BKKKPewsey » Mon Oct 17, 2011 10:04 pm
Bit of a kludge but you could use http://dreamscape.fm/ to convert from pls to asx stream
I just tested it with your link and it appears to work ok.
EDIT: Here is the link I am using http://dreamscape.fm/?action=play&q=http%3A%2F%2Feastmanchesterradio.com%2Flisten.pls
Postby monkey » Tue Oct 18, 2011 5:02 pm
Hmmm.... That's still not working here
I can't understand why we should need to convert to an ASX file, which AFAIK is Windows Media, and we're running Ubuntu / OSX.
Even more so the fact that JWPlayer will play a shoutcast stream, but not when it's put through Subsonic.... hmmmmmm.....
monkey
