Won't connect to server?
Postby thenameisryan » Fri Oct 21, 2011 7:43 pm
Okay let me re-phrase this,
The program I'm using is Isub for Iphone. I works for the most part when I'm home through wifi, some albums, don't work though, it just scrolls through all the songs as if they are second clips. As soon as I leave and get on a 3G network, only the songs I've played from home work and every now again the whole program works, but stops after about a half hour. It gives me some Error 1001? and sometimes says the Server is not available.
Any help? I don't know what I'm doing
thenameisryan
Re: Won't connect to server?
Postby BKKKPewsey » Fri Oct 21, 2011 9:04 pm
It would appear that Subsonic is working correctly from the very limited information you have given us.
If the problem is with the Isub client I would suggest that you ask on their own forum http://isubapp.com/forum/.
If Subsonic is giving you a problem please repost but have a read of http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506 first.
Postby thenameisryan » Fri Oct 21, 2011 9:34 pm
thanks for the info. I'll check that out.
thenameisryan
Postby thenameisryan » Sat Oct 22, 2011 11:19 pm
Okay,
I'm using Isub 3.0.4 on my Iphone and I keep getting this message
"Either the subsonic URL is incorrect, the subsonic server is down, or you may be connected to wifi but do not have access to the outside internet.
Tap the gear in the top left and choose a server to return to online mode.
Error code 2:
Request Timed Out"
I've tried logging in to subsonic on different computers, some of them work and others don't. I've tried reinstalling subsonic, "Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)" and it says it successfully forwarding port 8080. I'm not really sure what to do at this point.
I'm using Subsonic 4.5
Server Version: jetty-6.1.x, java 1.6.0_26
Windows 7
I'm sorry but I don't know where to find the java memory limit, I really have no idea what I'm doing and I'm sorry.]
Last ten log file lines:
[10/22/11 10:00:55 AM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 11:00:59 AM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 12:01:02 PM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 1:01:05 PM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 2:01:08 PM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 3:00:26 PM CST] INFO PodcastService Starting scheduled Podcast refresh.
[10/22/11 3:00:26 PM CST] INFO PodcastService Completed scheduled Podcast refresh.
[10/22/11 3:01:11 PM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 4:01:14 PM CST] INFO NetworkService Successfully forwarding port 8080.
[10/22/11 5:01:17 PM CST] INFO NetworkService Successfully forwarding port 8080.
I hope this helps out.
thenameisryan
Postby alphawave7 » Sun Oct 23, 2011 12:57 am
Review this install guide, and see where things might have gone loopy:
http://monroeworld.com/android/subsonic/
Be sure to test your chosen port number using www.canyouseeme.org to ensure it is indeed being forwarded properly. Cheers!
