Same Network Problem
Postby ragazoid » Sat Oct 22, 2011 9:47 am
Dear all,
I already install subsonic in my debian server, and every thing goes with no problem. I use this for local server, i mean, i don't use an IP public and it's not resolve to internet.
I use this for my internet cafe, and my problem is the play list will messed up if some one else access subsonic at the same time.
For example : client A make a play list with "BON JOVI" album inside, then client B doing something that can affect the play list, Boom, the play list on client A messed up. The play list change, following the changes from client B. It's only do on the same network.
Please help how to solve this problem.
Thank you
ragazoid
Re: Same Network Problem
Postby BKKKPewsey » Sat Oct 22, 2011 11:20 am
Are you using the web player on each client or the jukebox player?
Postby ragazoid » Sat Oct 22, 2011 12:00 pm
I'm using web player in my setting.
Here, i only create one user. :mrgreen:
I mean, how to make 1 client/pc can only use 1 player as default ( can not choose player ) if i create for ex. 30 player.
ragazoid
Postby BKKKPewsey » Sat Oct 22, 2011 12:56 pm
If I understand correctly what you are trying to achieve you could create a user for each pc e.g. pc1, pc2 ...........
You can give them all the same password.
Then create a link on each pc which will log that machine in automatically e.g. serverIP:portNo/subsonic/login.view?user=pc1&password=guest.
Each pc/user will then have their own player and hence playlist.
Postby ragazoid » Sat Oct 22, 2011 4:02 pm
yea, i got it. It means 1 player, 1 account for 1 pc right?
what if i have 100 pc's LOL....
but may be this is the only way...
btw, thank you for your help. :wink:
ragazoid
Users browsing this forum: Google [Bot] and 23 guests
