Dual core issue and how to reset encoders back to default?
Postby monkey » Sun Oct 23, 2011 1:12 pm
I've been trying to add "-threads 2" to my encoders, but for some reason it's not working
Here's what I've currently got as my mpeg transcoder
ffmpeg -threads 2 -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
OK, I should have tested this out on a couple of encoders first, but I didn't
Now when I remove the threads 2 option, I'm getting access denied errors on the movies that previously played OK
So, firstly, how can I easily reset my encoders back to their defaults?
Secondly, any idea why ffmpeg isn't playing nicely with a dual core processor (Ubuntu Oneric Server) ?
Here's the error log
Any ideas? Thanks in advance!
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) WARNING: library configuration mismatch
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) avutil configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) avcodec configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) avformat configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) avdevice configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) avfilter configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) swscale configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) postproc configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavutil 51. 7. 0 / 51. 7. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavcodec 53. 5. 0 / 53. 5. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavformat 53. 2. 0 / 53. 2. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavdevice 53. 0. 0 / 53. 0. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavfilter 2. 4. 0 / 2. 4. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libpostproc 52. 0. 0 / 52. 0. 0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 29.97 (30000/1001)
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Input #0, asf, from '/media/Storage/Movies/Family Guy/Family Guy - 15 Minutes of Shame.mpg':
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Duration: 00:21:48.87, start: 0.000000, bitrate: 411 kb/s
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 96 kb/s
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1: Video: msmpeg4, yuv420p, 352x240, 29.97 tbr, 1k tbn, 1k tbc
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [buffer @ 0x93ca780] w:352 h:240 pixfmt:yuv420p
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [flv @ 0x93d06e0] multi threaded encoding not supported by codec
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: flv, yuv420p, 352x240, q=2-31, 1000 kb/s, 90k tbn, 29.97 tbc
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: adpcm_swf, 44100 Hz, 2 channels, s16, 64 kb/s
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.0
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.1
[10/23/11 2:06:04 PM BST]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Error while opening encoder for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
monkey
Re: Dual core issue and how to reset encoders back to defaul
Postby beyondinferno » Sun Oct 30, 2011 9:16 pm
I was having a simular problem (running 10.04 though). Follow the guide in the ubuntu wiki to update ffmpeg and add in all the optional stuff in the guide. once it's done you have to change the symlink in /var/subsonic/transcoders/ for ffmpeg to the new install location. once that's done use this
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset fast -threads 0 -
Hope that helps.
beyondinferno
Users browsing this forum: Google [Bot] and 23 guests
