How do I view videos?
Postby jdavidw13 » Wed Oct 26, 2011 2:52 am
I'm using subsonic version 4.5. I've added my video folder to the "Media Folders" section under the setup option, similarly to how to added my music folder. The "General" setup section includes masks for the type of video media I have in my video folders. My question is, using the subsonic web interface, how do I browse my video media? The left frame, which shows music media by artist, didn't update to include my video media. How do I access it?
jdavidw13
Re: How do I view videos?
Postby BKKKPewsey » Wed Oct 26, 2011 12:03 pm
Does the video folder appear in the drop down folder list box?
Postby jdavidw13 » Wed Oct 26, 2011 3:01 pm
In several guides I've read, I've heard about this dropdown box. No, it doesn't appear for me. Where exactly is it supposed to show up?
jdavidw13
Postby jdavidw13 » Wed Oct 26, 2011 3:04 pm
Also, I should mention I have registered my subsonic server.
jdavidw13
Postby BKKKPewsey » Wed Oct 26, 2011 3:33 pm
In the left frame at the top under the artist/album/songs totals
e.g. http://forum.subsonic.org/forum/viewtopic.php?f=8&t=5554 which is showing a folder named TV
Postby jdavidw13 » Wed Oct 26, 2011 4:00 pm
Ok. It's definitely not showing up then. I've restarted the subsonic server after adding my videos folder as a media folder in subsonic. I'm not sure what to try at this point.
jdavidw13
Postby BKKKPewsey » Wed Oct 26, 2011 4:30 pm
Check that the folder is enabled
I would suggest a read of http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506
Knowing what you have installed SS on would help :?
Postby jdavidw13 » Wed Oct 26, 2011 5:27 pm
Problem Description:
The folder selection dropdown does not appear in the left-side media selection frame.
Troubleshooting Steps:
I've added my videos folder under the "Media Folders" section of configuration and made sure the "enabled" check box is ticked. I've confirmed the "Video Mask" under general settings includes the type of video media I'm trying to stream. I've restarted the subsonic server after making these changes.
Playback Application and version:
Web browser - Google Chrome
Subsonic Version:
4.5 (build 2384) – August 10, 2011
Server Version:
jetty-6.1.x, java 1.6.0_26, Linux (30.2 MB / 49.1 MB)
Hardware Platform:
Ubuntu 11.10
Java Memory Limit:
256m
Problem Filename
Output from ffmpeg -i:
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1, Copyright (c) 2000-2010 the Libav developers
  built on Mar 22 2011 15:35:22 with gcc 4.5.2
  configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  WARNING: library configuration mismatch
  libavutil   configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavcodec  configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavformat configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libswscale  configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
ffmpeg: missing argument for option 'i'
Last ten log file lines:
[10/25/11 8:40:54 PM MDT]   INFO   DaoHelper   Checking database schema.
[10/25/11 8:40:55 PM MDT]   INFO   DaoHelper   Done checking database schema.
[10/25/11 8:40:55 PM MDT]   INFO   SearchService   Automatic index creation scheduled to run every 1 day(s), starting at Wed Oct 26 03:00:00 MDT 2011
[10/25/11 8:40:55 PM MDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Oct 25 20:45:55 MDT 2011
[10/25/11 8:40:58 PM MDT]   INFO   NetworkService   Deleted port mapping for port 4040
[10/25/11 8:41:43 PM MDT]   INFO   VersionService   Resolved local Subsonic version to: 4.5
[10/25/11 8:41:44 PM MDT]   INFO   VersionService   Resolved latest Subsonic final version to: 4.5
[10/25/11 8:41:44 PM MDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.5.beta2
[10/25/11 8:42:03 PM MDT]   INFO   PlayerDao   Created player 7.
[10/25/11 8:45:55 PM MDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[10/25/11 8:45:55 PM MDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[10/26/11 3:00:00 AM MDT]   INFO   SearchService   Starting to create search index.
[10/26/11 3:00:00 AM MDT]   INFO   SearchService   Created search index with 1000 entries.
[10/26/11 3:00:00 AM MDT]   INFO   SearchService   Updating Lucene search index.
[10/26/11 3:00:01 AM MDT]   INFO   SearchService   Created search index with 1108 entries.
jdavidw13
Postby BKKKPewsey » Thu Oct 27, 2011 10:44 am
Hmm! most odd
How many media folders do you have listed/enabled in settings/media folders?
If you only have 1 music folder shown try adding another one.
Also change the theme that you are using which will force a refresh of the browser window.
p.s. I have deleted the duplicate post.
Postby jdavidw13 » Thu Oct 27, 2011 3:18 pm
Previously, I only had the "root" of my music library included as a media folder (also the video folder that wasn't working). After adding another media folder, the folder dropdown list showed up in the left frame. The folder list included my old music folder, the video folder I had previously added, and this new folder I added as a test. I'm not sure why it wasn't working before, but now I can at least get to my video media via the folder dropdown.
jdavidw13
