java.io.IOException: unable to resolve loopback connection
Postby epcos71 » Wed Oct 26, 2011 9:18 am
Hello forum,
I use subsonic 4.5 on Windows7 Professional (x64). When I installed it, everthing was fine (I also changed the internal port from 80 to 4040). I used it for three days and it was ok.
But when my server started this morning, I could not connect.
As it looked in the system tray there was the error message: "java.io.IOexception: unable to establish a loopback connection".
I changed absolutly nothing on the system. Even if the firewall (avira premuim security suite) is down, there is the error.
After a reinstall it temporaly worked on port 80, as i changed again to 4040 the error was back. Even a the change on 80 had no effect, the error is still there.
Here is my log, please help...
Regards michael
32 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1f934ad: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1f934ad]; startup date [Wed Oct 26 10:58:46 CEST 2011]; root of context hierarchy
94 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
453 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1f934ad]: org.springframework.beans.factory.support.DefaultListableBeanFactory@ca470
468 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@ca470: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
500 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files (x86)\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\2385
546 [main] INFO org.mortbay.log - jetty-6.1.x
905 [main] INFO / - Initializing Spring root WebApplicationContext
905 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
936 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1a0225b: display name [Root WebApplicationContext]; startup date [Wed Oct 26 10:58:47 CEST 2011]; root of context hierarchy
983 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
1046 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
1077 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
1124 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1a0225b]: org.springframework.beans.factory.support.DefaultListableBeanFactory@3a5794
1186 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@3a5794: defining beans [playerDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,musicFileService,securityService,settingsService,searchService,luceneSearchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheManager,userCache,musicFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of factory hierarchy
1248 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
1748 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
26.10.2011 10:58:48 net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
26.10.2011 10:58:48 net.sf.ehcache.Cache initialise
WARNUNG: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
WARNUNG: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
2232 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
2232 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
2232 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
2248 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 1343 ms
2295 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
2295 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
2295 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@831a91: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Wed Oct 26 10:58:48 CEST 2011]; parent: org.springframework.web.context.support.XmlWebApplicationContext@1a0225b
2295 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
2357 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@831a91]: org.springframework.beans.factory.support.DefaultListableBeanFactory@107dcfe
2404 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@107dcfe: defining beans [leftController,rightController,statusController,mainController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlaylistController,loadPlaylistController,savePlaylistController,changeCoverArtController,nowPlayingController,searchController,settingsController,playerSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,searchSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playlistController,xspfPlaylistController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,videoPlayerController,externalPlayerController,downloadController,donateController,multiController,wapController,restController,dbController,savePlaylistValidator,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@3a5794
2809 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 514 ms
3839 [main] WARN org.mortbay.log - failed org.mortbay.jetty.nio.SelectChannelConnector$1@1299f7e
java.io.IOException: Unable to establish loopback connection
at sun.nio.ch.PipeImpl$Initializer.run(Unknown Source)
at sun.nio.ch.PipeImpl.<init>(Unknown Source)
at sun.nio.ch.SelectorProviderImpl.openPipe(Unknown Source)
at java.nio.channels.Pipe.open(Unknown Source)
at sun.nio.ch.WindowsSelectorImpl.<init>(Unknown Source)
at sun.nio.ch.WindowsSelectorProvider.openSelector(Unknown Source)
at java.nio.channels.Selector.open(Unknown Source)
at org.mortbay.io.nio.SelectorManager$SelectSet.<init>(SelectorManager.java:279)
at org.mortbay.io.nio.SelectorManager.doStart(SelectorManager.java:201)
at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:308)
at org.mortbay.jetty.Server.doStart(Server.java:228)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$1.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at sun.nio.ch.Net.connect(Native Method)
at sun.nio.ch.SocketChannelImpl.connect(Unknown Source)
at java.nio.channels.SocketChannel.open(Unknown Source)
... 47 more
3839 [main] WARN org.mortbay.log - failed SelectChannelConnector@0.0.0.0:80
... 47 more
3839 [main] WARN org.mortbay.log - failed Server@1a631cc
... 47 more
... 47 more
3886 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
4915 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
5009 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.178.24:9412](local),objID:[0:0:0, 0]]]]
epcos71
Re: java.io.IOException: unable to resolve loopback connecti
Postby BKKKPewsey » Wed Oct 26, 2011 10:37 am
There has been another java update in the last few days which may have caused a problem.
Check the SS control panel and look on how much memory is being used also look at the subsonic log in c:\subsonic\
e.g. the one shown in the about/help tab
The log you posted was the install log from x86 program files.
