SubAir won't play!
SubAir won't play!
Postby krantul » Fri Oct 28, 2011 3:38 pm
Been using Subsonic with Android clients and web clients without an issue, but I'd really like to use SubAir on my desktop at work. I can browse my music collection fine, but nothing will play. Time doesn't increment, and it's not showing the total track time next to the slider either.
It behaves this way even on a machine on my local network. Any ideas?
krantul
Re: SubAir won't play!
Postby krantul » Sat Nov 12, 2011 1:31 am
Bump! Help?
krantul
Postby BKKKPewsey » Sat Nov 12, 2011 2:50 am
Does it show online (top right)
What happens if you load a saved playlist?
Also make sure you haven't got an AIR update waiting to install.
Postby kleverbear » Sat Nov 12, 2011 4:00 pm
krantul wrote:Been using Subsonic with Android clients and web clients without an issue, but I'd really like to use SubAir on my desktop at work. I can browse my music collection fine, but nothing will play. Time doesn't increment, and it's not showing the total track time next to the slider either.
Same here I tried it on Win7 and Ubuntu 11.04, on Ubuntu it would just freeze my system then crash. Had to remove it, on Win it would open and do nothing.
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
Postby Exrace » Sun Nov 13, 2011 7:22 am
Can you elaborate on your setup some?
Did your license get corrupted possibly?
I have AIR working using the https support in SS server but I use my own Astaro FW setup to NAT one of 3 ip addresses I have on the FW to my SS server on my home network. Works great.
Exrace
Postby kleverbear » Mon Nov 14, 2011 10:04 pm
Exrace wrote:Can you elaborate on your setup some?
I'm using Air and SS out of the box on my LAN only. Does air only work with lic. vrs of SS?
Ubuntu 10.04 LTS
6 Users
2,575 artist
2,053 albums
16,090 songs
kleverbear
Postby BKKKPewsey » Tue Nov 15, 2011 2:17 am
ALL apps which use the API require a licence after your trial period (28 days) is over. :mrgreen:
