Subsonic stops responding
Postby theeye » Thu Nov 03, 2011 3:36 pm
I have been using subsonic for a while, and love the app for Android!!
I registered it in August of last year and it has worked flawlessly till I did this last update
Version 4.5 (build 2384) – August 10, 2011
Server jetty-6.1.x, java 1.6.0_20, Linux (69.4 MB / 81.9 MB)
I built a new server running Centos 5.7, same as the old server, and pretty much set everything up the same.
The server has 2 nic's, one for local access in the house, and another with a static IP attached for DNS access remotely.
Recently I have noticed Subsonic stops responding to requests after a day or 2 of restarting it. I have checked the log file but I do not see anything in it that give me an indication of what went wrong.
What's the best way to troubleshoot this issue?
Is there a configuration change I should be making to resolve this?
my /etc/sysconfig/subsonic file contains:
SUBSONIC_ARGS="--max-memory=100 --port=80"
Will uping the max-memory maybe help?
any suggestions will be welcome, since it is a 'new' install, I figure it could be just about anything, but I am frustrated that I constantly have to restart subsonic to listen to my music. Since I have been using this, it's the ONLY source of music I draw from :D
Thanks in advance
Scott H
theeye
Re: Subsonic stops responding
Postby crazysam » Thu Nov 03, 2011 3:59 pm
Definitely up the memory limit, especially if you use a lot of players to move back in forth between your music collection. I'd try setting at 512, and see how it runs long-term.
crazysam
Postby theeye » Thu Nov 03, 2011 5:13 pm
Thanks crazysam
I have done that and restarted...
I will reply back here in a couple days and leave another reply. If it works it may help another.
Scott H
theeye
Postby theeye » Sat Nov 05, 2011 2:28 am
Upping the memory limit has seemed to resolve the issue. Has worked for me every time since.
Cheers!
theeye
Users browsing this forum: Google [Bot] and 26 guests
